Radar Detectors
Old Jun 6, 2009 | 11:52 AM
  #106
pcasupreme's Avatar
ohhh i wish radar detectors were legal in VA GOD DAMMIT LOLOL
Old Jun 6, 2009 | 12:06 PM
  #107
e\/olution's Avatar
id get the 9500 ci if it wasnt 4 times the price of a v1
Old Jun 7, 2009 | 05:39 PM
  #108
Clarko's Avatar
Originally Posted by GPTourer
I always take mine down after each use. I believe the direct sunlight and summer heat kills them after a year or two if you don't.
Is it a nussaince trying to put the radar detector up and back everytime? I have a gps that has to be mounted and I rarely use it, but when I do I hate it because it's annoying to mount and take off, if I don't put something wet on the suction cup it won't stick good enough, and it leaves a big spot on my windshield that only windex gets off. That's why I put mine under the visor. Even though I get good enough signals usually, I'm sure they'd be better if I had it on the windshield so I was just wondering how it's working out for you guys.
Old Jun 7, 2009 | 05:58 PM
  #109
mmartahus's Avatar
Yea anyone want to share how they have their radar detector mounted, what do you do about only having 1 power point in the evoX if you have a GPS that needs plugged in too? Any pictures you have of your set up would be greatly appreciated!
Old Jun 8, 2009 | 01:47 AM
  #110
boy36's Avatar
or direct wire.
Old Jun 8, 2009 | 10:09 AM
  #111
Vivid Racing's Avatar
Out here you need to take it down everytime you leave the car. Yeah it's a pain to do, but it keeps your detector from being fried by the heat.
My V1 isn't in the Evo, but I have it hardwired into the Accesory 2 power line - that way it turns on and off with the car, I don't have the cord hanging down from the windshield, and I don't lose use of the power outlet.
Old Jun 8, 2009 | 10:14 AM
  #112
GPTourer's Avatar
No. A nuisance would be buying another $400 unit next year. I can deal with suction cup marks.
Old Jun 8, 2009 | 11:37 AM
  #113
SiliconTek's Avatar
Beltronics Pro Series RX-65. I have had it for 4 years and never looked back...
Old Jun 8, 2009 | 10:00 PM
  #114
knightey's Avatar
Valentine One....had it for a year and love it....Saved me a couple times, radar is no joke in Toronto
Old Jun 9, 2009 | 03:18 AM
  #115
Narmy77215's Avatar
Old Jun 9, 2009 | 10:57 AM
  #116
mjesenovec's Avatar
I have a Beltronics GX65 Professional Series w/ GPS mounted just under the rearview mirror. I installed a hardwire kit, so all you see is 6-7" of power cable, and that's it. I set it up so my radar turns on and off with my ignition switch. i ran the cable straight up to the headliner, across the driver side, down the A pillar, under the dash, and used an add-a-fuse to tap into the fusebox by the driver's left knee. works like a champ, and looks clean.
Old Jun 9, 2009 | 11:50 AM
  #117
mmartahus's Avatar
sweet, do u have any pics of that set up, any issues with the A piller being an airbag cover? also which fuse did you tap it into? And where did you mount the mute/silence button
Old Jun 9, 2009 | 12:28 PM
  #118
mjesenovec's Avatar
I will try to take some pics after i get off work while it's still light. i dont remember which fuse i tapped into, maybe the radio? i just looked at the chart on the lid and picked one that only had power with the ignition on. the hardest part was getting to a screw to use as a ground. that required my dad's drill with a 6" extension to get to a screw. i will take some closeup pics of where i ran the cabling too. overall, it took about 30 minutes to do, because i had to poke around to figure how to do some of the stuff, but i could probably do it in about 20 now. i just barely tucked the cable inside the lip of the top of the a-pillar, so as to not disturb the airbag system. i also opted not to mount the mute/silence button anywhere. i just ran a straight power cable from my detector to the fuse box in the dash.
Old Jun 9, 2009 | 12:38 PM
  #119
svt04cobra's Avatar
V1 baby!!! Its the best!!!!!!
Old Jun 9, 2009 | 01:41 PM
  #120
newcomer81's Avatar
stealth install 2 months strong with no issues =) it already saved me on 2 specific occasions which would outweigh the ~$90 fine. using an escort 8550
