Radar Detectors
Old Jun 9, 2009 | 01:41 PM
  #121
mmartahus's Avatar
Originally Posted by mjesenovec
I will try to take some pics after i get off work while it's still light. i dont remember which fuse i tapped into, maybe the radio? i just looked at the chart on the lid and picked one that only had power with the ignition on. the hardest part was getting to a screw to use as a ground. that required my dad's drill with a 6" extension to get to a screw. i will take some closeup pics of where i ran the cabling too. overall, it took about 30 minutes to do, because i had to poke around to figure how to do some of the stuff, but i could probably do it in about 20 now. i just barely tucked the cable inside the lip of the top of the a-pillar, so as to not disturb the airbag system. i also opted not to mount the mute/silence button anywhere. i just ran a straight power cable from my detector to the fuse box in the dash.
great, pics would be much appreciated. i am picking up my hard wire smartcord for my escort 8500 detector from best buy today. i definitely dont want to do any drilling, hopefully i can find a place to ground the power that wont require that
Old Jun 9, 2009 | 01:46 PM
  #122
mjesenovec's Avatar
my mistake. i didn't actually have to DRILL anything. i needed the power drill and an extension to remove a screw i used for the ground wire that was tucked way up into the dash. i should have been more specific. there aren't too many choices for a ground screw under the dash, but i found one way up by the steering column. it really isn't too hard of an install. it takes more time to run the cable and tuck everything away than it does to actually plug it all in. i dont know why i opted not to get the smart cord...i just didn't see myself using it much i suppose, i just got the straight up power cord. Instead of taking pics, i might even grab my Flip Mino HD camcorder and make a little vid for you so i can actually point and explain what i did.
Old Jun 9, 2009 | 06:03 PM
  #123
mjesenovec's Avatar
made a video just as i left work. the video quality should be decent, as i recorded it with my 720p mino hd camera. kinda lame, but i get my point across and hopefully it helps somebody.
http://www.youtube.com/watch?v=WI4DVrafyKs
Old Jun 9, 2009 | 06:18 PM
  #124
mmartahus's Avatar
dude thanks so much, awesome video, i wish more people would do these kinda videos to help us all out
i think im going to do mine just like yours.
Old Jun 9, 2009 | 08:20 PM
  #125
mjesenovec's Avatar
ha. i'm glad you liked the video. i hope i explained everything ok. i thought the video was kinda lame, but it's not like i could make a video about pointing a cable very exciting no matter what i did
you also have the option of mounting the radar lower, flush with the dash, and running the cable along the bottom of the windshield. i chose the spot i did because A) the radar is very tucked under the rearview, so it does not obstruct my view B) running the hard wire cable in the headliner was easier and cleaner to do and C) the higher the detector is, the longer range you have on detecting K and Ka band.
Old Jun 9, 2009 | 08:37 PM
  #126
mmartahus's Avatar
yea, i know it probably wouldnt be good at all for detecting signals from the rear but im thinking i might mount it in the very top left most corner of the windshield. i think it will be out of the way and even if a cop came up to the car he wouldnt be able to see it as it would be up in the corner of the a-pilar and headliner and hard to see unless looking from below like the driver seat.
Old Jun 9, 2009 | 09:15 PM
  #127
mjesenovec's Avatar
i just know i haven't had a problem before with detection due to the location of the detector. i think it's funny that people mention placing their radar somewhere "cops can't see it." there's only like 2 places in the US where they're illegal. other than that, having a radar in plain sight like i do isn't a big deal...as they are legal. i've been pulled over before for speeding with my radar on, and my police scanner sitting in my cup holder, in plane sight, and nothing was mentioned. i guess i just never felt a reason to hide things i dont have to. i agree that it's important to know local laws and ordinances. but the fact is, radar detectors are perfectly legal to have in your car and use in 98% of the US...therefore there's no reason to be sneaky. If you get pulled over and a cop sees it, big deal, there's nothing wrong with having it.
Old Jun 10, 2009 | 06:15 AM
  #128
newcomer81's Avatar
the location would be perfectly fine for rear detection. i get rear signals just fine with my stealth install (https://www.evolutionm.net/forums/ev...h-install.html)
the rear facing sensor is for laser not radar. the radar detection you get from the rear is from the signal bouncing off of objects in front of you.
Old Jun 10, 2009 | 07:01 AM
  #129
mjesenovec's Avatar
hmm...i kinda wish i had made an actual how-to video when i installed it, then i would have been able to post it up on the how-to section.
Old Jun 10, 2009 | 07:45 AM
  #130
Gamble's Avatar
Originally Posted by svt04cobra
V1 baby!!! Its the best!!!!!!
I heart my v1. I had a passport 8500 blue and it was good, but not as good as the v1.
Old Jun 10, 2009 | 08:24 PM
  #131
EvoCop's Avatar
No radar detector will save you. It will just give you a heads up that youve been tagged!
Old Jun 10, 2009 | 08:41 PM
  #132
mjesenovec's Avatar
Well, yes and no. if you have been tagged, you will definitely know it, yes. But, if you are a half-mile down the road on a highway, you get a blip, slow down, and pass by a cop...he didn't actually clock you at that moment in time...you just detected further up the road. Radar detectors will save you if the conditions of that instance end up working out in your favor...but radar detectors will NOT ever save you 100% of the time, no.
Old Jun 14, 2009 | 01:33 AM
  #133
Dlove316's Avatar
soon to own V1
Old Jun 16, 2009 | 02:34 PM
  #134
svt04cobra's Avatar
Originally Posted by Clarko
Is it a nussaince trying to put the radar detector up and back everytime? I have a gps that has to be mounted and I rarely use it, but when I do I hate it because it's annoying to mount and take off, if I don't put something wet on the suction cup it won't stick good enough, and it leaves a big spot on my windshield that only windex gets off. That's why I put mine under the visor. Even though I get good enough signals usually, I'm sure they'd be better if I had it on the windshield so I was just wondering how it's working out for you guys.
I have mine hardwired and mounted with the windshield suction cups just under the tint strip in the front windshield. You can't even see it and its there clear as day. I have had a previous car broken into and they did not take the radar detector cause there are no wires and they were concentrating on the radio. That is the way to do it!!!!!!
Old Jun 16, 2009 | 02:36 PM
  #135
svt04cobra's Avatar
Yea anyone want to share how they have their radar detector mounted, what do you do about only having 1 power point in the evoX if you have a GPS that needs plugged in too? Any pictures you have of your set up would be greatly appreciated!
I'll take a pic and post it tomorrow. Not much to see its hardwired!!!!
