Depo oem style headlights
Old Mar 31, 2012 | 08:33 AM
  #91
RA173's Avatar
tested them yesterday against my other projectors and these were twice as bright.
and the cutoff is clean not like the pics in here which I am guessing is the camera picking up glare or something. Anyhow will install them in a few and drive with them for a week and decide if I will retrofit or not.
Old Apr 1, 2012 | 11:59 AM
  #92
Sinestra's Avatar
Anyone else have trouble getting Jrox DRL bypass to work. It seems like Depos are missing one connector needed for them to work properly
Old Apr 1, 2012 | 12:22 PM
  #93
jdmEviL8's Avatar
^ did you swap your OEM harness? i swapped mine just cause, and everything works great including my Jrox DRL bypass harness...
did you make sure you plugged everything in?
Old Apr 1, 2012 | 12:43 PM
  #94
wiretap's Avatar
The connectors on the Depo's are no different than the OEM connectors.
Old Apr 1, 2012 | 12:57 PM
  #95
Sinestra's Avatar
When the DRL is hooked up only the passenger comes on. The ballast works fine if we disconnect everything they come on normally but when the bypass is hooked up the drivers side won't come on
Old Apr 1, 2012 | 01:34 PM
  #96
wiretap's Avatar
Bypass is probably not done right.
Old Apr 2, 2012 | 04:42 AM
  #97
Sinestra's Avatar
Got it working for some reason the first bypass would not work. So i pulled out my old one made by funkybeats back in the day and it fire ok. However i discovered why my bumper had such a large gap on the drivers side. The inner clip that goes under the headlight was broken it was probably from an accident that i had a while back and it was never discovered but a guy i know fixed the issue by drilling new bumper support hole and adding additional bolts to compensate.
Lights are pretty good, cut off is decent not bad for $300 plus i have hardly any glare.
Old Apr 2, 2012 | 06:47 AM
  #98
manolo2011's Avatar
anyone of you had any issues with the passenger headlight? mine didn't fit well...i was missing one of the wholes pretty bad. did you had to force the headlight?
Old Apr 2, 2012 | 11:32 AM
  #99
wiretap's Avatar
All my holes lined up very close to the locations they were supposed to go. I didn't have any problems putting the bolts in.
Old Apr 2, 2012 | 01:29 PM
  #100
ninja99's Avatar
The holes for the passenger headlight were slightly off for me, but it wasnt bad enough that i couldnt make it fit.
Did you tighten one bolt down all the way before you started n the next? I didnt tight anything until all four bolts were threaded in. This allows the headlight move a bit if any of the other holes were off.
Old Apr 2, 2012 | 05:13 PM
  #101
RA173's Avatar
Mine lined up perfect on both sides!
Old Apr 3, 2012 | 11:42 AM
  #102
Mikey6273's Avatar
Purchased the depo headlights through Amazon as well as the depo smoked led tail lights, the ddm 35w 4500k hid kit, the jrox harness, and the 9500 high beam bulbs.
Question (I've seen talk of it here but not quite sure why/ necessary): Why are people "baking" and pulling the assembly apart? Is it necessary? Or can the bulbs purchased above just slide into the required housing?
Old Apr 3, 2012 | 12:29 PM
  #103
manolo2011's Avatar
Nope you wont have to bake anything. just bolt and plug and have fun...
Old Apr 3, 2012 | 06:05 PM
  #104
ninja99's Avatar
People do that when they wanna install a different projector or black out their headlight housing.
Old Apr 3, 2012 | 08:04 PM
  #105
jdmEviL8's Avatar
Received the Depo lights this last weekend and the quality is OEM right off the bat:
They immediately went into the oven to get blacked out. Oven baked @ 200 degrees for 23 minutes a piece and the sealant came apart with little force.
Here are the finished pics, I didn't add any sealant when putting them back together and have had a few rainy days since with ZERO fogging up. WELL WORTH THE MONEY!
