Depo oem style headlights
Old Mar 27, 2012 | 10:09 AM
  #76
rps13nismo's Avatar
Picked these up last week since seller is 2 miles from me but only thing is that im having condensation issues. Gonna seal the headlights with oem Nissan taillight gasket or permatex gasket maker lol…
Old Mar 28, 2012 | 10:30 PM
  #77
jkc213's Avatar
i want this, but what do i need to make this work properly??
i have non-sss headlight w/ DRL..
Old Mar 28, 2012 | 11:02 PM
  #78
tehSteve's Avatar
jrox harness to kill the hid flicker and it will completely eliminate your dtrl
purchase the projectors
purchase 9006 low beam hid bulb + 35w ballast
Old Mar 29, 2012 | 04:11 PM
  #79
Sinestra's Avatar
anyone tried adjusting these yet. I have mine installed but they badly need to be adjusted.
Old Mar 29, 2012 | 04:21 PM
  #80
jdmEviL8's Avatar
^ well first off, i would check if they even are adjustable...
Old Mar 29, 2012 | 08:12 PM
  #81
ninja99's Avatar
It took me a few tries, but I finally have mine adjusted to where I am happy with it. When I first mounted them the drivers side was way low and to the left. Passenger side was just a bit low but also to the left.
Old Mar 29, 2012 | 08:13 PM
  #82
ninja99's Avatar
This should help:
Old Mar 29, 2012 | 08:31 PM
  #83
Get Rad's Avatar
Think we could install the adjustable control on these to?
Old Mar 29, 2012 | 09:11 PM
  #84
iEvoVII's Avatar
^^ that's a definite NO to "adjustable controls" for these Depo headlights...
Old Mar 30, 2012 | 01:57 AM
  #85
iEvoVII's Avatar
How did you end up configuring you're high beam setup???
I spoke to 2 CZ4A owners in OZ that I did custom HLs for regarding the "flashing" issue..
Owner 1
* ADM Evo X MR with factory HID projector HLs (modified)
* High beam setup: FX-R projectors providing high beam (Twin set up only)
* Headlight wiring untouched
In the words of the owner:
....Yeah I can still flash the high beam if the low beam is off.. sometimes it takes a second to light up
Owner 2
* ADM Evo X GSR with factory Halogen HLs now fitted with JDM HID projector HLs (modified)
* High beam setup: Factory projectors providing high beam (Twin set up only)
I just tested it. I just flicked the stalk and both the cut off activated and the light switched on. Basically done what it should, switch the high beam on and skipped the other two steps.
^^ I'd say there's a good chance that USDM CZ4As won't have issues with flashing high beam despite my earlier comments that they would...
Old Mar 30, 2012 | 06:59 AM
  #86
Sinestra's Avatar
This should help:
Thanks Ninja thats what i figured the adjustments were i just wanted to see success rates. I am going to try to adjust mine this weekend when i fix the unsightly gap in my bumper from installing these.
Old Mar 30, 2012 | 12:21 PM
  #87
ninja99's Avatar
Owner 1
Owner 2
I didnt change the high beam setup. The high beam bulbs sit in the high beam reflector next to the projector.
Old Mar 30, 2012 | 06:51 PM
  #88
manolo2011's Avatar
i mounted mine today...for the passenger side there is a small gap between bumper and headlight...the screw next to the intercooler pipe didnt align... ...
Old Mar 30, 2012 | 06:53 PM
  #89
jdmEviL8's Avatar
got mine today, will be oven baking and smoking them out, and will post pics.
Old Mar 30, 2012 | 07:46 PM
  #90
tehSteve's Avatar
ok... so um....
what will I have to do in order to avoid any issues, run bixenon, and disable the halogen highbeam/dtrl completely?
and how the hell do you flicker you highbeams in base models lol?
I can only click it on and off. The quick pull and release method for the flicker is non-existent I tell ya!
