Factory reflashes, hesitation, stalling, and everything you need to know [merge]
Old Apr 10, 2008 | 06:17 PM
  #46
Rudager's Avatar
Originally Posted by STi2EvoX
I just called norco mitsubishi in california and they said that there is no dealer reflash there or anywhere. Which dealership did you say this was again?
This isn't like a real person to person conversation...you don't have to ask the person again...in the first post it says: Southcoast Mitsubishi
Old Apr 10, 2008 | 06:36 PM
  #47
thuan's Avatar
I don"t know the area real well, But isn't Southcoast Mitsubishi
like 10 min away from Mitsu-HQ, These guys can just walk over and pick up the new reflash CD. Maybe that is why they are the 1st to have the reflash..
Old Apr 10, 2008 | 06:37 PM
  #48
STi2EvoX's Avatar
I didn't notice that until I re-read it, don't be a smart ***.
Old Apr 10, 2008 | 06:44 PM
  #49
Kisada's Avatar
Good to hear about the reflash.
And as for Southcoast Mitsubishi ... they had a Phantom Black Evo X on their lot (actually 2 of them) the same day that 2 other mitsubishi dealers here in Southern California swore to me up and down that PB was an Evo MR ONLY color. I actually had 4 salesmen surround me and straight up argue with me in steadily rising tones of voice that I was dead wrong about the PB being available for GSR.
As I was about to turn and walk my a$$ out of there, the GM walks up to me and asks if there is a problem, I asked if he had access to the internet and he took me to a computer. I showed them the pictures SCM had posted of the PB Evos and just walked out.
That's why I'm driving 1 1/2 hrs each way, past 2 other Mitsubishi dealers I know of, to Southcoast to purchase my Evo.
Old Apr 10, 2008 | 07:10 PM
  #50
Tvall13's Avatar
Hey I have a cone filter on my car right now. Should I take it off to get the reflash and or just leave it on. If I take it off and put the stock airbox on will it mess up the reflash when I reset the Ecu by disconnecting the battery when I put the cone back on? What should I do?
Old Apr 10, 2008 | 07:19 PM
  #51
boostedgraphite's Avatar
nah the reflash would not be affected by disconnecting the battery...i would put the stock air box back in when u take it in just to be on the safe side since it only takes a few min
Old Apr 10, 2008 | 07:29 PM
  #52
Tvall13's Avatar
Ok cool thanks.
Old Apr 10, 2008 | 07:30 PM
  #53
unowned's Avatar
Originally Posted by Boostd4
That looks like it...guys?
TSBs are basically official notices that go out to dealers detailing issues that may occur in specific models. Not the same as a recall...more of just an FYI and how to fix said potiential problem.
wanna road trip to south coast with me ?
  #54
Deepseadiver's Avatar
My EVO X should arrive in GUAM in week, lets get some more info on that TSB!
Old Apr 10, 2008 | 07:31 PM
  #55
i would drive 8hrs for this...too bad its like 40 hours away from me
Old Apr 10, 2008 | 08:14 PM
  #56
Talon_66's Avatar
Originally Posted by DrasticK
It'll probably take another year for it to hit Canada
Im going to SS Mitsu tomorrow. I'll let you know
Old Apr 10, 2008 | 08:17 PM
  #57
EvoXstylin's Avatar
ok i'm interested in this
Old Apr 10, 2008 | 08:33 PM
  #58
Slimdatwelve209's Avatar
6hr drive for me if i go
Old Apr 10, 2008 | 08:39 PM
  #59
aznxkaiser's Avatar
Anybody in the Orange County area wanna caravan to Southcoast and get the reflash done?
Old Apr 10, 2008 | 09:51 PM
  #60
Dr. Ev0L's Avatar
PURPOSE
Some customers of affected vehicles may experience illumination of the malfunction indicator lamp (MIL)
with DTC 1320 stored in memory, or a drop in engine speed at idle. The Electronic Throttle Valve (ETV)
may learn an incorrect position when the ignition switch is turned to the OFF position from the ON position
without starting the engine.
If the vehicle is driven with this condition, the ETV mis-learns Idle Speed Control. As a result, the intake
air volume is insufficient to achieve an initial idle target of 1,400 RPM, causing DTC P1320 to be set, or
engine idle speed to drop.
This Technical Service Bulletin advises the steps to reprogram the ECM with new parameters and to perform
the ETV learning process .
AFFECTED VEHICLES
2008 Lancer Evolution X equipped with 5 speed manual transmission only built prior to VIN
JA3AW86V08U049108
