Fluttering sound after tune.
Old Jul 7, 2008 | 04:37 AM
  #31
SiC's Avatar
SiC
Originally Posted by eXstasy
Sounds like wastegate flutter to me. I don't know why everyone is talking about compressor surge. Compressor surge happens when you lift off the throttle and you are under boost and do not have a BPV/BOV to vent the pressurized air.
Yeah, sounds like wastegate flutter. This can be caused by several things. One is a weak wastegate actuator spring and can be correct by either getting a high capacity actuator or putting tension on your actuator spring by adjusting the wastegate rod (make it shorter).
Another thing that can cause this is an EBC trying to limit your boost and moving too aggressively (partially opening and closing the wastegate at a high rate). This usually happens at the highest boost which is usually around 3000-4500 RPM. My EVC is actually doing this and I'm trying my best to fix it.
J Yim
Jan 25, 2016 01:00 PM
caduprado
Jul 12, 2015 04:15 PM
lpy2009
Feb 26, 2012 12:09 PM
S2K2EVO
Jan 25, 2012 09:34 AM
dvd_mi
Mar 1, 2010 03:02 PM
