ECUFlash 1.40 is out!!!
Ive said it before and I will say it again. I have a cable and will help beta test if you guys need any more help. I have also have a licensed version of PCMSCAN for logging purposes.
I didn't know the PCMSCAN worked on the EvoX, does it work with the OpenPort 2.0 cable? Can it log knock?
WOW, that's a lot of work you did. Has anyone found all 3 speed limiter addresses yet? I know just adjusting that one did nothing, gunzo was stuck at 190km (JDM speed limit) at a track lol. You have to adjust all 3.
BTW, I saw that the older XML for the USDM had the labels for VVT intake 1 & 2 reversed and VVT exhaust 1 & 2 reversed.
It looks like the rev limiter variable has been found (actual one that really changes the limiter), I will be able to verify that shortly.
As far as I know the USDM doesn't have a speed limiter, same way the 8 and 9 didn't.
It shows 508km/h, which is 300+ mph I believe
Actually all the hard work was/is done by another beta tester. I cannot disassemble if my life depended on it. I'm good at testing and other things though.
Please?
