ECUFlash 1.40 is out!!!
Old Nov 1, 2008 | 09:54 PM
  #121
RazorLab's Avatar
Originally Posted by SiC
So you gained over 60whp & 30 torque on a stock Evo, NICE!
Yes, 100% stock except for 18x10 volks and 275 tires
91 octane, Kalifornias finest.
Old Nov 1, 2008 | 10:09 PM
  #122
Deepseadiver's Avatar
good numbers!
Old Nov 1, 2008 | 10:26 PM
  #123
Rguy's Avatar
Looks good! Stock boost and mivec?
Old Nov 1, 2008 | 10:34 PM
  #124
RazorLab's Avatar
Factory boost control tuned. 23psi peak, 17psi at 7200 on this one.
Mivec tables where tuned. Still more in the mivec though...
Old Nov 2, 2008 | 03:41 AM
  #125
gunzo's Avatar
Aw come on!!!!
You can push the stock 300 barrier can't you ??
With 91 pistane .. can you run 19-21psi at the upper rpms ??
I bet you're wetting yourself with how easy it is to control boost eh ??
I'm almost done with all the maps
Old Nov 2, 2008 | 04:53 AM
  #126
Robevo RS's Avatar
guys can you possibly in the near futue delete the TPMS and the airbag warnings?
Old Nov 2, 2008 | 10:45 AM
  #127
RazorLab's Avatar
Originally Posted by gunzo
Aw come on!!!!
This one is maxed out up top. 20 psi at 6500 then it drops to 17 at 7200. The other one I had on the dyno the other day held about 2psi more up top.
Boost control is nice. I've been tuning factory boost control for about two years now so it's basically the same now but with 3D tables and no need for a boost pill on these stock 10's.
I am going to be testing out our boost pills on a 10 here soon.
I can't wait to see more maps gunzo. You da man.
Old Nov 2, 2008 | 11:58 AM
  #128
Stormtrooper's Avatar
can't wait to see things mature on the X... looks like the next few months will be a lot of FUN!!!!!
Old Nov 2, 2008 | 04:53 PM
  #129
verkion's Avatar
Outta curiousity, are you tuning with the wastegate mod? (i.e. tightening the clevis a turn or two?) Can you see how that will affect it? It's a really really really quick mod...took me like 15 mins to do. It's supposed to let you hold a little more boost, isn't it?
verkion
Old Nov 2, 2008 | 04:58 PM
  #130
RazorLab's Avatar
verkion
No I haven't touched the WGA yet. I might fiddle with it on a modded X but on a stock one I feel the boost is at a good level for 91 octane.
Old Nov 2, 2008 | 05:27 PM
  #131
gunzo's Avatar
verkion
My car has the wastegate mod .. but my car is slightly different from what you guys have
Maybe it helps .. maybe it doesn't .. haven't test on a car without the mod yet .. but so far I can sustain 21psi (with room for 24-25 psi easy) up til 7000rpms and tapering off to 19psi by rev cut ..
Old Nov 2, 2008 | 05:40 PM
  #132
Rguy's Avatar
Got rid of the horrible, horrible, horrible upper RPM power drop off this weekend.
Pulls hard even past redline now.
JDM mivec = winnar too.
Old Nov 2, 2008 | 05:42 PM
  #133
gunzo's Avatar
If the test is done by the engine ECU .. yes probably .. like the O2 delete on the IX's ..
The airbag has a different ECU .. so I don't think that is possible ..
I suspect the TPMS is controlled by the ETACs ECU .. so then again .. maybe not
Don't rule out though .. so far .. the cable can send control info to the rest of the ECUs on the car .. I won't be surprised if someone hacks it later .. I'm just waiting to Hack the freaking ETACs so I can get at the functions thats disabled ..
Old Nov 2, 2008 | 05:44 PM
  #134
gunzo's Avatar
Here's a guide .. set the midrange exhaust mivec from 2500rpms to 4000rpms at
-5 instead of 0's .. and then wipe that grin off your face everytime you step on the throttle
Old Nov 2, 2008 | 05:52 PM
  #135
SiC's Avatar
SiC
Shhh, don't let out all the secrets
I can't wait to see the reaction for all these people once they start flashing their Evos. I really think that ANYONE can make their Evo faster, it really looks like they detuned this car from the factory.
