ECUFlash 1.40 is out!!!
Old Oct 20, 2008 | 09:49 PM
SiC's Avatar
SiC
Grab it from the OpenECU site here.
Old Oct 20, 2008 | 10:04 PM
wickedchimp's Avatar
No luck here. I get the following message when i try to read the rom.
[00:03:01.515] Flashing tools do not recognize flash method 'mitsucan'
What version of ecuflash are you running??
Old Oct 20, 2008 | 10:32 PM
PR_Mivec's Avatar
im guessing 1.40 for the tittle of the thread?
Old Oct 20, 2008 | 10:36 PM
AWD Motorsports's Avatar
Interesting..ill have to check it out./.
Old Oct 20, 2008 | 10:39 PM
PR_Mivec's Avatar
just tried it.. but EVOX is not on the 'read' list... how did you managed to read the rom?
Old Oct 20, 2008 | 11:03 PM
I know there are atleast two builds of 1.40
Old Oct 21, 2008 | 02:27 AM
SiC's Avatar
SiC
I'm using Version 1.40.2173 but it seems like they removed it and put up a crippled version of it. Sorry, I didn't know they crippled the current version.
Old Oct 21, 2008 | 03:56 AM
RREvoX08's Avatar
From: Tallahassee, but currently reside @ Camp LeJeune
hows that infometer touch sic
Old Oct 21, 2008 | 04:21 AM
SiC's Avatar
SiC
Not bad at all, it can log for up to 15 min and you can hook up an external wide band that outputs 0-5v. I have my AEM WB hooked up to it and it works fine.
The only downside is that it cannot output the log to any external device. You can only view it on the monitor itself and it gets erased if you turn the car off. The peak hold and settings remain but the recording log gets erased.
Old Oct 21, 2008 | 06:34 AM
Have you been able to write with 1.40.2173? Ive tried to modify the rpmlimit but the car wont start when I write the modified rom. I am able to write the original rom back in successfully though. Thank god.
Old Oct 21, 2008 | 06:46 AM
goofygrin's Avatar
Immobilizer code dude...
Old Oct 21, 2008 | 06:56 AM
Yeah that completely slipped my mind because I was so excited...lol Has anyone found it yet?
Old Oct 21, 2008 | 08:23 AM
A418t81's Avatar
Originally Posted by Deepseadiver
Piggybacks are NEVER equivalent to a properly reflashed ECU. They may be able to make similar power, but the consistency is poor in comparison. If you want to race on a dyno they are fine. Also, eventually piggies fade into obsolescence as the tuner picks a newer platform to use for their piggyback unlike ROM flashing which continues development. Been there done that man, I have a very very expensive Xede for a paperweight from my Evo. In shorter time than people realize, the same will be true of the piggies for the X. Patience is a virtue. Wait or get an ECUtek flash.
Old Oct 21, 2008 | 08:24 AM
+1
Old Oct 21, 2008 | 08:37 AM
Noize's Avatar
EvoM Administrator
Zchip promotion in this thread is unwanted and has been removed, as this is an Ecuflash thread. If you want to talk about chipping your car, use the appropriate thread already in this forum.
