COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Jan 28, 2009 | 12:12 PM
  #541
Rob@cobbtuning's Avatar
Originally Posted by S2K2EVOXGSR
Once again I can I get a good write up or copy of the PDF of the requirement for the STG II ???
If you remove the pill how will that react if I started to use other maps like back to Stage1 or econo??? Will there be a messed up reading??? I find it difficult if everytime you want to put it into Econo or other stage mode you would have to insert the pill on and off again...
Please see the map notes for your particular map in question. It will explain what modifications are ok for that tune.
http://www.accessecu.com/accessport/.../EVOXMaps.html
When running the Econo maps, the turbo is running wastegate spring pressure. No issue there with our without the pill. Even then you are going for economy, no need to stuff your foot in it. If you have stage II modifications there is no reason to run stage I tuning and in fact could be hazardous to you motor to do so.
Thanks,
Old Jan 28, 2009 | 12:14 PM
  #542
Originally Posted by R0ME0
Robb,
Will we have problems if we take out the restrictor pill to run the stage 2 map but then when going to the dealer loading a stock map back on running without the restrictor pill?
Running a stock tune with a restrictor pill removed could cause over boosting. That being said running a stock tune with stage II modifications will most likely produce poor results as well.
Thanks,
Old Jan 28, 2009 | 12:37 PM
  #543
COBB Tuning's Avatar
Stage 2 maps for the EVO X are now available on the Cobb Tuning website.
Stage 2 modification requirements and boost control system changes are explained in the Map Notes and Instructions, respectively.
Regards,
Gary Sheehan
Director of Marketing
COBB Tuning
Old Jan 28, 2009 | 05:03 PM
  #544
Originally Posted by LVSBB6
I noticed the Stage II gains on the MR maps are slightly lower than the GSR:
26% HP / 17% TQ vs 28% HP / 19% TQ
Whats the reason behind this?
Tim says the tranny is not slipping leading me to believe the SST has higher parasitic drag than the MT.
Thanks,
Old Jan 28, 2009 | 06:22 PM
  #545
STiEV0's Avatar
Originally Posted by Rob@cobbtuning
...In several cases stock cats can be a bit of a back up, but this does not seem to be the case with the Evo X. It looks to be the cat-back which is the restriction in the exhaust.
Thanks,
Rob, Having said this would it be possible to modify the boost system and run a cat-back exhaust with the Stg 2 map? Obviously in lieu of the full TBE. -Thanks
Old Jan 28, 2009 | 06:36 PM
  #546
alex3dworld's Avatar
i just got a call from a friend
he say that cobb promises a full exhaust system for February?
Old Jan 28, 2009 | 06:42 PM
  #547
With a replacement of the cat with a test pipe would most likely require a custom tune. The Evo X is very touchy about the tune vs. the modifications.
Something to keep in mind, that extra boost may not give you any power. Tuning is about a balance of parameters that gives the motor what it wants to run most efficiently. As you have most likely seen with the over boost or under boost codes, you cannot just up one parameter without playing with others.
Thanks,
Rob do you think i'm fine if i just get the cobb down pipe and cattles pipe with the stock mufflers to run the stage 2?
adding the cobb intake sistem too ofcourse?
Old Jan 28, 2009 | 07:36 PM
  #548
Papi4baby's Avatar
Regards,
Gary Sheehan
COBB Tuning
Any HP claims? Thanks.
I wonder if is more power than the Perrin Stage 1 AP tune!!!
Old Jan 28, 2009 | 08:05 PM
  #549
lowkey's Avatar
Registered User
People, the Cobb stages are very clearly written:
Stage 1 is an otherwise stock car.
Stage 2 is a TBE exhaust and with wastegate solenoid pill removed.
They have not released maps for other permutations or combinations of pipes, intakes, filters etc . If your car does not fall into any of the Stage categories EXACTLY then you need a custom tune.
Old Jan 28, 2009 | 08:18 PM
  #550
cplise's Avatar
Hey Rob?
Could we not just use This -------> http://www.maperformance.com/perrin-performance-boost-control-solenoid-e.b.c.s..html.
I realize its not cobb but wouldn't it work? Forgive me if i am not understanding the "Pill" problem?
Old Jan 29, 2009 | 04:39 AM
  #551
pltek's Avatar
COBB AccessTUNER RACE and Dataloger Discussion !
i hope that this thread will be used for discussion about these 2 apps.
Old Jan 29, 2009 | 04:42 AM
  #552
pltek's Avatar
Having said that i would like to run 1st scenario and hopefully someone or Rob from COBB will chime in.
1. I am about to reflash my evo but before i do, i would like to download my current map and compare it to a stock one. (i would like to do that because i am not sure if the map i bought the car with is stock) How do i do that?
2. I am also curious weather AccessTUNER Race has a build in logger (i assume it does) and what widebands are compatible with it?
3. is there a manual on how to use the tuning app? ( i know there was one for streettuner)
Thanks
Old Jan 29, 2009 | 06:43 AM
  #553
chase123's Avatar
I don't think you are able to access the map that the AP downloads from your car upon installation.
Old Jan 29, 2009 | 07:14 AM
  #554
pltek's Avatar
i hope you can with the tuning soft
Old Jan 29, 2009 | 07:51 AM
  #555
linjy2's Avatar
i guess its safe to say we cant modify the stage 2 maps with this software huh, because it wont let me load it.
i want to raise my rev limit and two steps, but seems can only be done on the stage 1 maps. =(
