COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Jan 30, 2009 | 11:06 AM
  #571
chase123's Avatar
Originally Posted by pltek
i appreciate that but i want to download my "stock" map and look at it because i bought the car slightly used and it feels like it pulls a lot more than a stock evo i drove at a dealer. Cobbs stock map would be a good reference in this case
I'm still fairly certain you cannot access the map that the Accesport downloads from the car during installation. It doesn't show up in the file manager. Maybe you could see it during live tuning. I'm not sure if that feature is available yet though.
It makes sense now that I think about it. The map saved during installation is the one that gets reinstalled when the Accesport is uninstalled from the car. If you were able to change that map, the car would then have a tune map installed when the Accessport is divorced. Cobb wants your car to be exactly how it was pre AP when you uninstall. Otherwise you could tune many cars with one AP.
Old Jan 30, 2009 | 12:34 PM
  #572
Papi4baby's Avatar
+1
I believe there's no way to mess with the OEM maps.
Old Jan 30, 2009 | 12:35 PM
  #573
pltek's Avatar
hi Rob
can you kindly answer my question directly as to whether there is a way for me to download my stock map and look at its tables using AccessTNER Race (one i have on my car now ) before ever do any reflashes with AP or AccessTUNER Race?
Originally Posted by Rob@cobbtuning
Another option would be to open the software and hit <ctrl-k>. This will set all the maps back to stock values, so be sure to save any work you have done before doing so.
Thanks,
Old Jan 30, 2009 | 01:13 PM
  #574
Rob@cobbtuning's Avatar
hi Rob
I'm sorry, I thought I had answered your question. Lots of questions to answer. There is no way for you to access the map save on install.
Thanks,
Old Feb 3, 2009 | 03:24 PM
  #575
EVO X/GSR's Avatar
FYI if you Flash it and take it to the dealer for service they will flash it and you will lose your AP.
Uninstall before service.
I purchased my EVO in august and already there are 3 new downloads out. UGH
Am I right on this?
Old Feb 3, 2009 | 03:38 PM
  #576
linjy2's Avatar
Am I right on this?
edit*
there are new flash from the dealer, its been posted. but you dont need that if you are getting an AP or any other type of tune. I didnt get any of the tune from the dealer and just got the AP off the bat.
Old Feb 3, 2009 | 03:44 PM
  #577
Am I right on this?
If you uninstall before you go to the dealer they cannot flash over the AP's flash given the ECU has a stock flash. Reinstall when you get the car back.
If the AP is installed the dealer will not be able to access your ROM to flash.
Thanks,
Old Feb 4, 2009 | 02:24 PM
  #578
chase123's Avatar
Don't know if this has been mentioned, but 1.3.2.0 update with software dyno has been released. No info on the website to see if there are any other changes though.
Old Feb 4, 2009 | 09:08 PM
  #579
Jblade's Avatar
Good lookin out man! For those that don't know, you have to check "Look for Beta Firmware" in the AccessPort Updater app, or else it'll just say you have the latest firmware. Can't wait to play with it this weekend!
Old Feb 5, 2009 | 01:42 AM
  #580
Methodical4u's Avatar
has anyone had a baseline run done and then with the AP stage 1 run ? I am curious to know what sort of HP increase there is.
Old Feb 5, 2009 | 09:48 AM
  #581
scarryy's Avatar
Yes, Methodical,
look in the dyno results section. As an added testimonail from a butt dyno, I just flashed the 93 oct Stg I map onto my GSR, and there is a BIG difference. Pulls like a mother up to the redline and no longer sounds like it is gargling on fuel over 5000 rpm. Now it runs the way it was intended to. At some point I'll go to Cobb SLC and get a custom tune, but for now I am in happytown!
Also super easy to do and took about five minutes total to save my old map and flash on the new. Cobb AP FTW!
Old Feb 5, 2009 | 10:19 AM
  #582
Papi4baby's Avatar
Originally Posted by scarryy
Yes, Methodical,
I will say the contrary. Yes there's a difference. But BIG is not it. The power delivery is better, and overall it does make a difference.
Old Feb 5, 2009 | 11:11 AM
  #583
scarryy's Avatar
Well Papi, beauty is in the butt dyno of the beholder I suppose... However instead of fighting its way from 5000-7500 it now rips on through and its time to upshift. So yes, I would say it is a big difference. Probably around 40 HP, but NO I don't have dyno #s.
It feels pretty consistent with the dynosheet posted by JuniorAWD.
https://www.evolutionm.net/forums/ev...yno-sheet.html
I saw your post "I guess I was expecting more..." and was kinda worried, but having tried it, I am happy for an off the shelf map. Will I get a custom tune at some point to squeek out some more? Sure will. But for now I have a car that pulls hard to redline and doesn't gurgle under WOT.
I saw you tried the Perrin map too, how do they compare on your butt dyno?
Old Feb 5, 2009 | 01:20 PM
  #584
Papi4baby's Avatar
Perrin has a way nicer torque band. I think HP is the same, but the torque is there with the perrin.
Old Feb 5, 2009 | 02:18 PM
  #585
Perrin's site says 40-50 whp.. on the dyno pic however it shows that to be flywheel hp.
Question also.. if I were to buy from Perrin's website, does it come with their maps as well as the base maps from Cobb?
RocketSkates14
14
Dec 6, 2013 10:18 AM
Stevo-9
Feb 4, 2011 04:09 PM
MonacoGP
May 18, 2009 03:44 PM
AutoMotoSports
Automotosports - Illinois
15
Nov 9, 2007 01:33 PM
Turbotoyzz
Nov 19, 2006 05:00 PM
