COBB AccessTUNER Pro for 2008 EVO X (merge)
Last edited by Rob@cobbtuning; Jan 21, 2009 at 01:54 PM. Reason: Equation was backwards.
AP Stg II Questions...
Hi Guys,
As of right now Tim is working on the Stg II calibrations. The hope is there will not be a need to have pill changes, but that is not set in stone.
If pill changes are necessary Cobb will have what is need for those who don't want to create their own setup. For those who want to create their own pills, we will release the specs of the pills we use.
We'll keep you updated.
Thanks,
Thanks,
I have created a new thread for Stg II questions and updates.
https://www.evolutionm.net/forums/ev...questions.html
Thanks,
Thanks,
What we have learned is the cat-back is a decent restriction and the stock cat is pretty good.
Thanks,
rob,
i updated and downloaded the tuner race program. i was messing around with your valet map and wondering why you guys chose to put the rev limiter where it is? is it ok to put it lower like around 4k for both in gear and stationary?
i won't be messing with maps otherwise unless i think i know what i am doing.
rob,
