COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Jan 21, 2009 | 02:20 PM
  #406
Rob@cobbtuning's Avatar
Originally Posted by Black-X
So subtract 14.7 from the total?
-X
If you are at sea level, that is a good estimate. Otherwise you can check the local weather.
Old Jan 21, 2009 | 02:25 PM
  #407
lowkey's Avatar
Registered User
Originally Posted by LVSBB6
So I suppose you need to have a laptop to run this program, and for every changes you make on the map, you will have to upload back to the AP and then flash it to the ECU.
Works like a ECU flash, but a few extra steps in between.
I will have to try it out at my next dyno session.
The software has a ECU menu item with the following options: Live Tuning / Data logging / Reset ECU. I think that means you don't have to follow the flow of first uploading to AP and flashing from AP. But once you have the maps on the AP, it's far more convenient to take the small AP than a laptop everywhere you go. The new AP firmware flashes the ECU in just a minute or so.
Old Jan 21, 2009 | 03:16 PM
  #408
dek0026's Avatar
goofy you can install it if you install all the AP drivers i bet. you don't need the AP connected to the PC to use the program just to transfer the map.
Old Jan 21, 2009 | 03:21 PM
  #409
linjy2's Avatar
nice!, i cant wait for the stage 2 and bigger pill.
Old Jan 21, 2009 | 03:35 PM
  #410
LVSBB6's Avatar
I personally hope it does not require a pill, can`t wait to see the results.
Old Jan 21, 2009 | 03:42 PM
  #411
LVSBB6's Avatar
Does it mean you can perform live tuning by connecting the supplied AP cable & plug from the OBD2 plug directly to the labtop/computer when tuning?
Once its done, the map can then be uploaded to the AP?
Old Jan 21, 2009 | 04:06 PM
  #412
Japistani's Avatar
Originally Posted by lvsbb6
i personally hope it does not require a pill, can`t wait to see the results.
+1
Old Jan 21, 2009 | 04:09 PM
  #413
S2K2EVOXGSR's Avatar
hey last question about setting live data
once i plug it in my computer to set my log I get ecu comms
cable not connected or mis-configured and when i hit cancel it freezes
Old Jan 21, 2009 | 04:11 PM
  #414
I just noticed that we changed that behavior. It'll be fixed in the next release.
Thanks,
Old Jan 21, 2009 | 04:17 PM
  #415
dek0026's Avatar
Ok, so just to be sure are these the corrects steps to follow?
1-download map
2-import map into AP manager
3-connect AP
4-drag and drop map from AP library to AP
5-reflash ECU
how about deleting maps from AP and following steps 1-5? did i screw something up? i haven't done step 5 yet.
btw rob. i know we probably drive you nuts with all the demands and endless questions but you support makes me and i am sure others thrilled that we went with the AP over other products
Old Jan 21, 2009 | 04:31 PM
  #416
Japistani's Avatar
Originally Posted by dek0026
i know we probably drive you nuts with all the demands and endless questions but you support makes me and i am sure others thrilled that we went with the ap over other products
+1,000,000
Old Jan 21, 2009 | 04:41 PM
  #417
John83's Avatar
edited....nvm, i was reading old posts about the slight issue with the boost reading atmospheric pressure + boost.
thanks Cobb and Perrin for being there!!!
heres part of the log, i added a column that subtracts 14.7lbs, arg, can't copy past part of spread sheet very well, oh well im sure you'll get the idea.
RPM Abs.Prsr ACTUAL
2910 5.66 -9.04
2945 6.6 -8.1
3047 13.49 -1.21
3257 21.1 6.4
3647 33.58 18.88
4159 35.53 20.83
4690 34.95 20.25
5074 33.94 19.24
5490 34.37 19.67
5895 35.53 20.83
6265 34.37 19.67
Old Jan 21, 2009 | 05:41 PM
  #418
You can delete maps and then re-upload the new maps from the web to your AP if you like. Totally up to you. Step 5 will fix live data as long as you have an updated map.
You guys drive me a little nuts, but that's what we're here for, right?!
Thanks,
Old Jan 21, 2009 | 05:51 PM
  #419
HB Speed's Avatar
Thanks,
Hi Rob !
Old Jan 21, 2009 | 06:07 PM
  #420
goofygrin's Avatar
From reading the doc this looks possible.
It's trying to communicate with the AP to update it during the install.
