ASC Off Light under high load??
Old Jun 9, 2010 | 05:11 PM
  #106
newcomer81's Avatar
Originally Posted by tephra
tps is being restricted by ASC..
ie the ASC sends a torque modify request to the ECU.
ECU pulls TPS to satisfy that torque modify request.
a by-product of that is boost drops...
GHEYER than *** on a mustache
(charts aren't scaled the same but you can see the tps drop and the boost dip)
Old Jun 9, 2010 | 06:43 PM
  #107
tephra's Avatar
Originally Posted by criptballer
i'm sorry to join the conversation late here, but is there a way to disable or fix the light from coming on at high load then? i sometimes hit it while doing freeway pulls in third gear and sometime it doesn't.
Tephra, are you saying that we could be losing power from this since the asc tries to control our torque and pulls torque if we go over the limits? i've tried adjusting my torque limit tables but it still comes on no matter what the values on the torque limit tables are, along with airflow. Even if i hold the ASC button down for 5 seconds and disable everything, it still shows up at high loads. should i be worried?
a) no
b) no, some people are contending that ASC restricts power, I am asking for logs of this
ASC WILL send a torque modification request when it detects wheel spin, OFF/OFF mode should block this behaviour
Old Jun 9, 2010 | 09:22 PM
  #108
GST Motorsports's Avatar
Is that logged TPS or APP?
- Bryan
Old Jun 9, 2010 | 09:49 PM
  #109
tephra's Avatar
Jesse - What are you saying?
Old Jun 9, 2010 | 10:57 PM
  #110
criptballer's Avatar
a) no
ahhh so nothing to worry about except an annoying light coming on when i do WOT pulls. good to know.
Old Jun 9, 2010 | 11:05 PM
  #111
tephra's Avatar
thats our current understanding
Old Jun 10, 2010 | 05:14 AM
  #112
newcomer81's Avatar
- Bryan
might be coincidental but that dip in TPS was right when i was going to break 30psi. i have a bit of catching up to do, just got in the office. i'll get the log up here in a little bit.
Old Jun 10, 2010 | 06:08 AM
  #113
newcomer81's Avatar
i wasn't logging WGDC error correction to see if that came into play, i'll get some new logs tonight. unfortunately i just have this 1 3rd gear pull (the other pulls the error already kicked asc off)
here is tps & boost scaled correctly. it may just be coincidental that the tps drops a few points after i break 30 and tripping the warning screen.
after looking at this a bit, it looks like it dips every time i break 30
Old Jun 10, 2010 | 08:37 AM
  #114
Golden's Avatar
Can I ask what your equation for logging boost is? The part I'm interested is the "-14.5" part. I curious what you are subtracting for Atmospheric Pressure.
Old Jun 10, 2010 | 08:48 AM
  #115
newcomer81's Avatar
14.5 i live at sea level
Old Jun 10, 2010 | 09:15 AM
  #116
that's interesting that your TPS does that when you go wot, fluctuate. Mine stays solid at 96 the whole time i'm wot.
Old Jun 10, 2010 | 09:42 AM
  #117
Clipse3GT's Avatar
Same here, but my max boost is 28 psi... not close to 30 psi...
Might be some salt to this if you approach close to 30 psi your TPS fluctuates...
Old Jun 10, 2010 | 09:53 AM
  #118
newcomer81's Avatar
it's only 2 more psi.. go for it!
ivan308
Jun 6, 2017 06:01 AM
ddlopresti
20
Apr 10, 2017 09:39 AM
Marc2192
Dec 4, 2016 03:25 PM
daasca
Jul 7, 2016 06:47 AM
Illest92til
Sep 17, 2015 06:00 AM
