Installed WB today... questions..
Old Jun 14, 2010 | 10:38 PM
  #106
Methodical4u's Avatar
Originally Posted by charon2123
Check fuse #12 (red, 7.5A), you might have blown it when you were fooling around in there. I did the same thing and got the airbag code, as well as ASC service, etc... Are you able to get to the O2 sensor, ie dropping the TP/HFC? If so, drop it and turn the car to on (not cranked) and put your hand near (not on) the sensor. If it warms up you'll know it is wired correctly.
I just checked the 7.5's... all of them and a lot of others, but no luck finding a broken one... don't know what else to do except either hope someone knows which one it is, or i'll have to check them all 1 by 1.
Old Jun 15, 2010 | 06:27 AM
  #107
charon2123's Avatar
You will actually have to pull the fuses (7.5A) because they will show up as good even when they are not, ask me how I know... Try tapping into the cigarette lighter or the windows, they have higher amperage and seemed to work well for me; I had the Zeitronix and LC-1 hooked up to those.
Old Jun 15, 2010 | 07:05 PM
  #108
yeah, can't use the sig lighter... I made it constant power so my phone could always charge.
Old Jun 15, 2010 | 07:44 PM
  #109
ok, I wrote this once, only to hit the wrong button and exit the page... real nice... ANYWAY. I went to a few stores today, Kmart (didn't have a serial to USB) a place where they work on comps, didn't have it. Anyway, I didn't get to see if the serial cable had an issue or not with it, but when I got home I looked again at Innovate's online manual and their paper manual and they have discrepencies between them. I have the brown and white wire connected and the yellow wire capped off, as the paper instructions say that it's for use of dimming the gauge when the lights are on... the online one doesn't say anything about that, though maybe I missed it. Soooooo, the online manual says to use, one and/or the other... perhaps I need to have the yellow wire soldered in there with the brown and white?
Old Jun 15, 2010 | 07:46 PM
  #110
tephra's Avatar
For the LC1:
white is system ground
yellow/brown are analog outputs (both customisable, one defaults to NB thou, cant remember which)
black = calibration+status LED
Not sure about the gauge
Old Jun 15, 2010 | 07:58 PM
  #111
Originally Posted by tephra
For the LC1:
ok, so if I put the yellow wire (both are analog out wires) with the white and brown that I already have together, will that let this program open?
Old Jun 15, 2010 | 09:10 PM
  #112
tephra's Avatar
NO..
this is the LC1 we are talking about right (not the gauge)
yellow and brown wires are seperate, they are both analog outputs, so one to the gauge, one to the ECU - or whatever you like
white is a system ground, it should be grounded to the same place as the BLUE wire.
black is the calibration wire and should connect to the LED but also to a button which will ground it
red is power - obviously.
Old Jun 15, 2010 | 10:38 PM
  #113
NO..
For the LC-1 according to the manual the hook ups are as follows...
Red -12 V supply
Blue-Heater ground
White-system ground
yellow-analog out 1
brown-analog out 2
black-calibration wire
so I guess I will have to check my wiring all over again... I thought I had the white and blue together like the manual says.
Old Jun 15, 2010 | 10:46 PM
  #114
however, what am I supposed to do with the analog outputs? Just tape them off? The yellow and brown wires?
Old Jun 15, 2010 | 10:55 PM
  #115
tephra's Avatar
you can just tape them off - one of mine is taped, the other goes to the rear02 input on the ECU.
Old Jun 16, 2010 | 01:17 AM
  #116
what was the reason for that?
Old Jun 16, 2010 | 10:55 AM
  #117
ok, so I got the blue and white wires correct... they were right before... the brown is going to the white wire to the gauge. I am pretty much out of options and will have to call innovate and if I can't get it right, get another gauge that will work properly. Oh, and the letting the car sit all night with the battery disconnected didn't do a damn thing.
Old Jun 16, 2010 | 11:18 AM
  #118
I thought as long as it had power, it had power and it was the same? Besides that.. and i'm not saying you are wrong in your statement, but the instructions only call for as little as a 5 amp fuse.
Old Jun 16, 2010 | 11:39 AM
  #119
Called mitsu and got the explanation that the airbag code is a hard fault code? It would have to be hooked up to a diagnostic tool to be checked, the dealer is 45 minutes from me so now I will have another 15.00 or so dollars in gas for this WB... i'm pretty well sick of it now and i'm ready to box it up and get rid of it... if I take it to mitsubishi I will have to get rid of all of the wiring anyway otherwise they will fault me for the issue... which maybe I am at fault, I didn't realize an airbag system was going to be so sensitive. Anyone got any ideas on mods in the 300.00 range I can put on this car that WON'T need a WB that I could get to add a little more power to it?
Old Jun 16, 2010 | 12:21 PM
  #120
charon2123's Avatar
Did you try physically pulling the fuses, all the ones you touched with the wiring?
