View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Apr 4, 2008 | 08:07 AM
  #61
love9sick's Avatar
It is notchy at low engine speeds...oddly enough when running the car to red line the shifts are incredible. I haven't miss shifted the car once and no grinds at all that are not driver error.
Old Apr 4, 2008 | 08:13 AM
  #62
Joe's Evo X's Avatar
Originally Posted by aznxkaiser
Anyone else have this problem?
Not necessarily grinding but I dont know how to explain it, sort of a notchy type of feeling. This is my first manual trans car and I do not know if all cars feel this way but sometimes the car will not left me shift into a lower gear? Like if I am cruising at 4th and wanted to downshift, it will not let me engage 3rd smoothly...or not at all..
Dont take this the wrong way but you said this was your first manual so it might be for inexperence of driving the car. Give it time and let you skill get better to see if it improves if not the it might just be the car. (i remember my frist time driving a manual )
Old Apr 4, 2008 | 09:17 AM
  #63
madfast's Avatar
are you blipping the throttle to match revs? cruising in 4th and then downshifting into 3rd the rpms will jump. you have to blip the throttle to match revs. if you're already doing this then i've no clue what's going on. if you haven't been doing this then give it a try.
Old Apr 4, 2008 | 10:37 AM
  #64
GSXR's Avatar
There is a little bit of notchiness when cold but it's not bad at all. I finally observed what some of you guys are seeing when shifting from 1st to 2nd, and 2nd to 3rd. I get the same slight crunch when I shift fast. Not bad. Hopefully, it goes away.
My STi was much worse. It was really notchy for the first 10k miles. I had to change my driving style. Order went from - lift off gas, step on clutch, then shift - to - step on clutch, lift off gas, shift. It felt a little weird but it worked for shifting fast.
Old Apr 4, 2008 | 11:02 AM
  #65
shyong's Avatar
I think it may have something to do with not having a independent reverse gear. I think the 1st and 2nd gear work together for reverse. I noticed sometimes it has problems getting into reverse. What I do is put it in 1st and move up a bit then get into reverse. I noticed this resolves the problem.
It seems as though this also solves the whole 1st-2nd-3rd gear notchiness. That's what I can come up with for now.
Old Apr 4, 2008 | 11:27 AM
  #66
tinkerbellevo's Avatar
be leary...
i had my transmission replaced, my notchy got grindy quick, lol - 1143 miles and it was like i was gonna cry everytime the car shifted... new tranny doing ok 1600-1700 miles now and its notchy but i try to ignore it, not really sure but i think its not as notchy as the first transmission
Old Apr 4, 2008 | 03:08 PM
  #67
Brahmzy's Avatar
Unvbelievable on a $35K+ car. So many issues with the tranny - Mitsu better step up. I am NOT going to drop $35K on this thing when all I hear about are first-year headaches.
Old Apr 4, 2008 | 03:28 PM
  #68
tokeone's Avatar
these trannys have no issues
just cry babies behind the wheels.
its my 3rd mitsu, all trannys have felt the same.
get used to it or buy something else
Old Apr 5, 2008 | 07:29 AM
  #69
su37su's Avatar
Dude, I've owned a IX and had no problems with it, at about 17k miles 2nd and 3rd gear syncros were out, and it got notchy then started to grind every time I shifted. This is how my X feels, at first it was notchy and now its starting to grind. This is not normal.
Old Apr 5, 2008 | 06:54 PM
  #70
typoist's Avatar
this is my third mitsu as well but my X grinds every time 1-2 2-3. It doesn't matter if i am going slow or fast. Doesn't matter if it's in high rpm or not. But if you slow down your shifts (i.e pause while shifting, or double clutch) then there is no problems. But i shouldn't have to do that on a $42,000.00 car.
Old Apr 5, 2008 | 07:12 PM
  #71
aznxkaiser's Avatar
haha thanks
When do you blip the throttle?
It may be my inexperience but I think I am pretty good now haha No more stalling, now more super slow starts...smoother shifts etc ! I just hate how every integra on the road wants to race me ! I just ignore them and cruise in 5th (But still end up beat ing them on the highways )
Old Apr 8, 2008 | 03:34 PM
  #72
finallyaevowner's Avatar
yes and no
if i would have been ask when the car had between 0 and 800 miles i would say it shifted like a dream but know it is not really grinding but rubbing all the time in different gears at different times dose not seem to have any consitiant issue but it is offten
Old Apr 9, 2008 | 07:20 AM
  #73
REDEVO08's Avatar
I feel your pain..This is the only car I owned that notched into gear like this..It hurts to shift..But on the up side I would have to say where it counts in high RPM shifts like a dream..Dont have to worry about grind or missing a gear..
Old Apr 9, 2008 | 02:55 PM
  #74
Reboot's Avatar
mine is now grinding heavy into 3rd - went to the dealer today - you can read up on all the details at
http://mitsunation.net/showthread.php?p=119283
Old Apr 10, 2008 | 04:03 PM
  #75
meffiez28's Avatar
Registered User
Mine is notchy 1-2, 2-3.
I talked with my service manager, and he spoke with the instructor running the Evo class for the techs and he said the X he drove to the class did the same thing.
He claimed that this was "normal" during the first few thousand miles and the car learns itself and breaks in drivetrain components.
Now I'm not sure if I believe this or not. But that's what I was told.
