View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Jul 29, 2008 | 12:03 AM
  #211
jrsimon27's Avatar
have any of you guys that are experiencing a notchy transmision burn up the clutch? you can even burn the clutch on a slight hill its so easy to do.
i ask cause i my evo 8 when new had a smooth gearbox but after burning the clutch while drag racing it became notchy and to tell you more that car i made like 100+ drag passes also made 7000rpm launches and the stock clutch died out at 24,000miles.
also when cold the tranny was more notchy then when it was warmed.
sorry to hear all this complains it makes me stay away from the new gsr model.
Old Jul 29, 2008 | 12:09 AM
  #212
jrsimon27's Avatar
o one more thing i tried bg syncroshift II but didnt like it it was much better with the diaqueen oem oil
Old Jul 29, 2008 | 12:24 AM
  #213
Papi4baby's Avatar
Originally Posted by STi2EvoX
Well, although the new thread that I started was closed and redirected to this one, I would like to keep this topic alive in hopes of making people get more involved with voicing these concerns to their dealers and to mitsu corporate. If people don't complain then mitsu will dismiss the few that have complained and do nothing about it. It doesn't matter if we can use "specal techniques" to avoid the grinding and crunching, it shouldn't have to be that way and it's unacceptable. 6 months of waiting with no resolve from mitsu is unacceptble and they need to be reminded of that.
Oh i will voice my concern once the first service comes along. I have a few things to voice alright.
Old Jul 29, 2008 | 06:47 AM
  #214
scottatyamaha's Avatar
+1
Old Jul 30, 2008 | 03:49 PM
  #215
tinkerbellevo's Avatar
I haven't gone anywhere, i have complained still. Again, its not nearly as bad, but its still an issue. My car is going in for service soon, and hopefully the local mitsu rep will be able to see it. My local service manager left, yipee, he actually went to toyota (which is what my husband has, thats how i know where he went) the new manager may>? be better assistance.
I have also had issues with the skirting ground effects, they just look crappy (loose i guess - who knows)
I have had 2 unduplicatable idle issues where i have dropped to about 400 or 500 rpm and it felt as if it were going to stall when completely stopped and no air or anything runnin?!?!
Old Jul 31, 2008 | 03:07 PM
  #216
Thegame's Avatar
I think the first TSB for VIII synchro issues was dated in November of 2003. I'm not exactly sure when the first VIII arrived in 03, but I think it was at least 10 months prior.
It's now August and the X has been out for what, 7 months? I think by the end of the year there will be a TSB for the tranny. They're not doing anything at this piont because they aren't sure what to do. Engineers and such are trying to come up with a cheap way to fix the problem. If there even really is a legitimate problem. I'm sure they've tested fluids and such and that would be a cheap and easy fix. So that probably isn't the answer. I just hope they don't write it off as "normal design and function of a performance tranmission."
Old Aug 7, 2008 | 02:28 PM
  #217
Thegame's Avatar
Since the manual calls for a GL 3 75W-80 gear oil, what are we supposed to use? Nobody besides mitsu markets such an oil in GL 3. Redline MTL would be a perfect choice except it's GL 4. It's also a 70W-80 oil which would probably help some of the cold shifting woes. Who knows though, maybe Mitsu did this on purpose to protect the synchro's until the oil warms up. Maybe a 70W is too thin???
Old Aug 18, 2008 | 06:30 PM
  #218
BlueoctaneevoX's Avatar
My X has 7000 miles and after I hit 1500 the grinding slowly went away and it has only gotten smoother. Mine shifts nice and it shifts even nicer at 7000 rpm. : )
Old Aug 19, 2008 | 02:23 PM
  #219
Thegame's Avatar
If the transmission grinded then I'd be worried. Mine is just notchy. I have noticed a slight improvement though at 2600 miles. + the AMS shifter bushings and Works base bushings helped a bit.
Old Aug 25, 2008 | 11:08 AM
  #220
evohead1's Avatar
I just got my tranny fluid changed(11900) and it feels soo much better!!
Old Aug 25, 2008 | 01:12 PM
  #221
STi2EvoX's Avatar
^Factory fluid or did you go with something else?
Old Aug 28, 2008 | 12:39 PM
  #222
su37su's Avatar
I think we could just use the same fluids that we used on the VIII, and IX.
This is just a perfect excuse for mitsubishi to use to void warranties, If anything other then oem fluids are used.
Old Aug 30, 2008 | 08:40 PM
  #223
NateDaJew's Avatar
I solved most of the crunch by blipping the gas between shifts until she warms up.
Old Sep 10, 2008 | 02:18 PM
  #224
EVIL_EVO_VIII's Avatar
im getting the same notchiness from 1st to 2nd is the worst either with the car cold or warmed up. I also have it from 2-3rd..It some how feels like my other Evos, but the 1-2nd gear sometimes crunches bad, feels almost like a grind..If it continues or gets worse, im taking it in for warranty
Old Sep 10, 2008 | 02:43 PM
  #225
EvoXCrazy's Avatar
Going from1st to 2nd for me it crazy from crunches to grind to even a bang(metal hitting metal). Reverse also hard to engage often 2 to 3 times before it locked into place.Fyi only got 653 miles on my car..
