CBRD wins the least expensive power mod award...
Old Sep 7, 2008 | 03:20 AM
  #181
EVOxStuntin2008's Avatar
Well I did the mod anyways with 2.5 turns. I don't think that I could have gone much further than that. Seemed like it was pretty close to the ending point. Haven't had a chance to test it yet. Keep everyone updated when I get to drive it a little bit.
Old Sep 7, 2008 | 06:40 PM
  #182
EvoNiner1986's Avatar
That's very interesting...
Old Sep 7, 2008 | 09:43 PM
  #183
Jabjab's Avatar
I have had the 3.5 turns on mine now for about a month no cels no problems just feels like it holds boost better above 5k
Old Sep 12, 2008 | 06:45 PM
  #184
gunzo's Avatar
When you say turns .. do you mean every 1/2 rotation of the eyelet or 1 complete turn ???
mine can only go 4 1/2 turns max before reaching the ends of the tread ..
Old Sep 12, 2008 | 06:47 PM
  #185
I turned mine a total of 2.5, as in 5 half turns of the eyelet. I haven't had any problems so far. Car feels great.
Old Sep 15, 2008 | 11:12 AM
  #186
evostang's Avatar
Below is a link to the DIY I wrote previously. I am going to remove the DIY from my storage space in a couple weeks, and at that time this link will be broken. If anyone wants to download and re-host it, that would be fine with me.
http://bellsouthpwp.net/j/r/jrude/wa...ctuatorDIY.pdf
Jared
Old Sep 15, 2008 | 11:13 AM
  #187
evostang's Avatar
1 turn = 360 degrees.
1/2 turn = 180 degrees.
Old Sep 15, 2008 | 05:51 PM
  #188
mksevo's Avatar
Did this mod ,after my ECUtek tune , Definitely improved power on upper end. peak 24ish. drops to 20 ish. will post if any sel .
Old Sep 15, 2008 | 07:34 PM
  #189
Robevo RS's Avatar
so which is the safe adjustment on this? 1.5 -2.5-3.5 turn?
i'm planning to try it/ i haveno tune yet though...
Old Sep 15, 2008 | 08:22 PM
  #190
Hiboost's Avatar
Originally Posted by Hiboost
2 Turns - Min Boost at mid RPM was 22-23 PSI, boost tapers to 20 PSI @ redline
2.5 Turns - Min Boost at mid RPM was 24-25 PSI, boost tapers to 21 PSI @ redline
3 Turns - Minimum boost at mid RPM was 26-27 PSI , boost tapers to 22 PSI @ redline
3.5 Turns - Not possible in my car, which means mine was already a 1/2 turn tighter than most from then factory from what I can tell.
Basically the angle of the internal WG flapper was starting to induce boost creep on my car at my mod level. I chose to back it down to 2 turns since the mid RPM boost creep was just too uncontrollable. I noticed that even at 2.5 turns the boost would creep to 25 PSI in 5th at the mid RPM's which wasn't really good if I wanted to run lower boost at a road course. I also tested a direct boost line to the WG and got 15-16 PSI base then it creeped up to the mid RPM numbers above the same as when I was using the MBC.
From what I can tell the extra boost you get beyond 20 PSI at redline on these stock turbos is likely just not worth forcing out of the turbo. We'll see if I can get the same (or better) trapspeeds with 2 turns versus 2.5 turns at the drag strip after my clutch goes in.
I'll re-quote myself with one addition: Since my car would not get 3.5 turns like some have, it was already about a 1/2 turn tighter than them. Seems like 1 whole turn from Max was the sweet spot for my setup. 1/2 turn from max I started to get too much boost creep at the mid RPM's and zero turns from max was raising my minimum boost way above my comfort level.
Old Sep 16, 2008 | 04:20 AM
  #191
Robevo RS's Avatar
so what are you saying is, to being safe the 2 turn worked best for you/ since you said yours was a half turn tighter then others, from factory/
so if i will do a 2 turn mods just for see the result and staying the safe side.
Thanks.
Old Sep 16, 2008 | 04:49 AM
  #192
mksevo's Avatar
From reading here , it seems that 2 - 2.5 turns worked the best most of the time. as always its best to check your boost levels and spikes. watch for any SEL . thats where I started. doing more boost reading today .
Old Sep 16, 2008 | 07:04 AM
  #193
Hiboost's Avatar
Thanks.
Yes that sounds about right, but as always you should check how the boost levels are effected on your specific car.
I replaced my stock actuator last night with a Forge and will have some data to post soon.
As for adjusting the stock Actuator I have one more engine blowing mod you can do if you "run out of adjustment" and want higher boost and more preload. You could easily place a washer or two on the actuator mounting bolts to add preload or cut off 1-2 threads from the end of the rod which would allow the eyelet some more adjustment range. Personally I think it would limit the travel of the wastgate flapper too far and cause crazy high boost in the midrange, you have been warned!
Old Sep 16, 2008 | 07:39 AM
  #194
Robevo RS's Avatar
I did it. i did 2.5 half turn but i didnt drive the car yet .
It is very weird i could turn the a little nob 4 and a little times...
so mine actually was looser from factory?
Anyway i did go back to the factory settings and turned it 2,5 times tighter.
When i will drive i wll give you guys my opinion on this. /if its count /
Thanks for the help!
Old Sep 16, 2008 | 11:01 AM
  #195
Robevo RS's Avatar
i tryed it. Yes defenietly noticeable change. My car have a dropp in, and the downpipe back exhaust. the car defenietly feel more responsive and smoother.
My question is, why the Mitsu tuned and adjusted badly the X ?
Can you guys imagine if this car did come out, tuned right and adjusted right , in those tests against other cars?
Now i just nedd a Sean Tune!
Thanks CBRD!
