CBRD wins the least expensive power mod award...
Old Aug 17, 2008 | 10:43 AM
  #166
415EVOX's Avatar
You can do this mod if you have no tune. But if you have a tune dont do this. You will get a SES causing a bigger spike in boost. Expect to see the P1235 code if you do this mod with a flash. Only good for cars without a flash.
Old Aug 17, 2008 | 10:59 AM
  #167
POMPOUS_JACKASS's Avatar
Not necessarily true, it may depend on what order you do this in. I have this mod done together with a tune with no problems.
If you tune first then do this mod, I can forsee SES possibly coming up.
If you do this mod first then tune for it, you should have no problems whatsoever
Old Aug 17, 2008 | 11:09 AM
  #168
415EVOX's Avatar
How many turns did you do? What flash did you get? Sounds kinda fishy when no details are added
Old Aug 17, 2008 | 11:26 AM
  #169
evostang's Avatar
The detail in his post is no less than the detail in your post.
would this raise boost or just the boost taper? what if my ecu boost is set @24?
It will raise both the maximum boost and the boost at redline, which is what I assume you mean by boost taper. Whether or not you get a CEL depends greatly on what kind of tune you have. With a generic mail in flash tune that does not compensate for the wastegate actuator mod, you will probably get a CEL. A custom tune taking into account for the wastegate actuator mod should not produce a CEL, assuming the tuner knows about the mod and knows what they are doing.
Old Aug 17, 2008 | 11:55 AM
  #170
2 turns, ECUTek and custom tune. I'm not sure what is fishy about it. When tuning is performed, the tuner will optimize the settings, taking into account the modifications that are on that car.
If you are talking about a mail in reflash, then the order in which you mod or flash your car won't matter. You would be equally likely to get (or not get) an SES no matter what order you mod in. Perhaps I should have been more specific. I have a custom tune, not a pre programmed tune on a flash
Old Aug 18, 2008 | 06:40 AM
  #171
CBRD's Avatar
i havent tuned a X yet, but my assumption is that it will help holding a little more boost up top, without running excessive WGDC's through the stock solenoid.
cheers
cb
Old Aug 24, 2008 | 07:15 AM
  #172
CamaroSS_2002's Avatar
All this talk about Boost and Butt Meter but has anyone checked the AFR's and put this to the dyno? -- I tried to find somewhere in this thread where someone has done it and maybe I missed it.
This mod sounds very promising but more boost does not always equal more power if the car is pulling timing...
I'm referring to the additional turns past the 1 turn mentioned at start of post...
Old Aug 24, 2008 | 07:40 AM
  #173
CBRD's Avatar
we did test it on the dyno, afr's pulled up slightly, obviously helping with making power, because the car is pig rich from the factory...
and it held more boost to redline.
cb
Old Aug 24, 2008 | 07:58 AM
  #174
cb
How many turns have you tested? Just 1?
I'm trying to find someone that has tested 3.5 turns.
Old Aug 24, 2008 | 10:09 AM
  #175
superman37r1's Avatar
I got the full 4 turns out of mine and it pulls very nice up top...
Old Aug 24, 2008 | 12:24 PM
  #176
Hiboost's Avatar
2 Turns - Min Boost at mid RPM was 22-23 PSI, boost tapers to 20 PSI @ redline
2.5 Turns - Min Boost at mid RPM was 24-25 PSI, boost tapers to 21 PSI @ redline
3 Turns - Minimum boost at mid RPM was 26-27 PSI , boost tapers to 22 PSI @ redline
3.5 Turns - Not possible in my car, which means mine was already a 1/2 turn tighter than most from then factory from what I can tell.
Basically the angle of the internal WG flapper was starting to induce boost creep on my car at my mod level. I chose to back it down to 2 turns since the mid RPM boost creep was just too uncontrollable. I noticed that even at 2.5 turns the boost would creep to 25 PSI in 5th at the mid RPM's which wasn't really good if I wanted to run lower boost at a road course. I also tested a direct boost line to the WG and got 15-16 PSI base then it creeped up to the mid RPM numbers above the same as when I was using the MBC.
From what I can tell the extra boost you get beyond 20 PSI at redline on these stock turbos is likely just not worth forcing out of the turbo. We'll see if I can get the same (or better) trapspeeds with 2 turns versus 2.5 turns at the drag strip after my clutch goes in.
Old Aug 24, 2008 | 05:27 PM
  #177
DVDee's Avatar
I got tuned before I did this mod and I now have almost two months since I did this, no lights have come on, on the car.
Old Aug 24, 2008 | 07:07 PM
  #178
Papi4baby's Avatar
With the mail in flashes it might cause a problem. But if you do the turns and do a dyno tune, you would be ok. Should be.
Old Aug 31, 2008 | 05:49 PM
  #179
NateDaJew's Avatar
I just finish the mod. I found it to be crazy easy(until I dropped the pin).
I feel her pulling harder without any lights or creeping. Thanks for the write up.
Old Sep 6, 2008 | 06:54 PM
  #180
EVOxStuntin2008's Avatar
Is this mod ok with the second stock reflash. I think if I do it I will just do 2 turns since I am in Hawaii and at sea level.
