CBRD wins the least expensive power mod award...
Old Jun 24, 2008 | 11:30 AM
  #106
Noize's Avatar
EvoM Administrator
Originally Posted by evostang
How did you ultimately get it back on?
3.5 turns was worth 5-6 psi on my car across the board.
I drove it to work today, 80 miles round trip, and used a combination of cruise control and just regular driving. I spent long periods of time (as long as possible at least) in part throttle high boost situations, transient low boost to high boost part throttle, and lugging the car along at low RPMs letting boost come up to 15-ish psi in fifth at 2500 RPM part throttle, etc, all in an attempt to get the car to throw a cell. Never got a cell. Hope it continues like this.
Its not going to throw a CEL because you are using ECU controlled boost still. The P1235 CEL happens from an MBC and like 22psi from like 20% throttle where the car is in cruising load cells and fueling set at stoich. It sees it as an unsafe condition with the MBC because well, it is.
I have tried from 22psi to almost 25psi peak. No matter what, the turbo tapers to 17psi at the rev limiter way up top. Power difference between 22psi and 24psi is negligable, she's blowing hot air in the midrange. This car likes fueling changes more than anything.
Old Jun 24, 2008 | 11:35 AM
  #107
Noize's Avatar
EvoM Administrator
Originally Posted by qubit
So I spent some time messing around with this mod yesterday, here is what i found. I have an intake, exhaust, boost gauge and a mbc. I was getting a 23->17 boost curve with my mbc.
I first tried 1.5 turns, readjusted my mbc to maintain my stock boost level, and didn't really notice any difference. I tried again with 3 turns, then 3.5. At 3.5 turns, i was able to make an additional 1psi at redline, giving me a 23->18 boost curve. However, it seems to hold boost better the entire way through, and it seems faster all around. I wasn't able to make 19psi at redline like some of the others, however, I am in denver, at 5280 feet the stock x turbo is probably struggling for air.
Unfortunately, i had a couple problems on the way to work. My car started idling at 2k rpm, unless i had the ac on. (If i turned the ac on the car idled fine.) Once i turned the car off and back on this went away and hasn't come back. However, i'm fairly sure this is related to my cone air filter. The other issue was my SES light came on...I haven't checked the code but i didn't notice any gimp mode.
This mod is really easy to do, if i continue to have problems I can reverse it in about 20 min.
The code is a P1235 because you're running too much partial throttle boost with the manual boost controller.
The high idle is a side effect from the code.
You don't feel the effects of the limp mode because your ECU boost is disabled. If it was hooked up, you would be seeing 12psi.
Old Jun 24, 2008 | 12:04 PM
  #108
evostang's Avatar
Agreed that it will most likely not throw a CEL with factory boost control. However, it's worth trying in order to see what happens.
Old Jun 24, 2008 | 12:18 PM
  #109
Noize's Avatar
EvoM Administrator
Oh, you can make it throw on factory boost control. The easiest way would be to turn off boost correction in the ECU.
My car does not like 24+ psi in the midrange on 93 octane with the way its tuned and tends to get fussy and detonate. Yours will too when you lean it out. With boost correction and barely tapping 23psi in the middle, its smooth as silk.
Old Jun 24, 2008 | 12:45 PM
  #110
qubit's Avatar
So in order to avoid the CEL, is it best to remove the mbc and use the stock boost control solenoids? it seems people are able to do so without as many problems...
Old Jun 24, 2008 | 12:58 PM
  #111
freshman209's Avatar
I got it back on with just plain brute force. But in all honesty after I got it back on the first time, it was pretty easy to get on and off after that. I'm not sure what was going on but I've messed with it a few times now with no problems. Thanks again for the help.
I've still got no cel and I've also tried to drive it at various throttle positions in different gears. It sounds like it's pretty clear that there is no cel as it is still using factory boost control. I'm still not sure if this is a better way to increase boost than using an MBC. I think in a few days I will put on my MBC and mess around with it a little bit. Again thanks for the help guys.
Old Jun 24, 2008 | 01:02 PM
  #112
qubit's Avatar
For those of you not using a MBC, what is your boost curve like after you perform this mod?
Old Jun 24, 2008 | 04:16 PM
  #113
love9sick's Avatar
So this is producing these great results with out the MBC? I am going to skip on the MBC anyways. I just wanna now what would be safe to turn. 25psi seem a bit much for peak boost. I wish it just tapers a lot less. I wanna get a boost gauge before I do this anyways.
Originally Posted by CBRD
our power numbers are back with better fuel, not quite what they were, but last time we did thr 280/281 pulls it was 52 degrees, now its consistently 80 degrees and higher, which is why we are down about 10whp... (plus the 19x10's are on it now)
cb
Is there any way you could more or less specify what "better" fuel means. Where I live we have BP, Shell, Mobil1, Marathon. Which one of these you think wouldn't cause the loss of power or which one would you tank up.?
Old Jun 24, 2008 | 04:41 PM
  #114
trans_lux's Avatar
Noob question-what would the results be with this mod combined with a tune say something like the AMS mail in flash? Would you want to do this before or after or never?
Old Jun 24, 2008 | 06:09 PM
  #115
STi2EvoX's Avatar
Originally Posted by gunzo
Well .. just add my observations in ..
Tested this on 2 totally stock JDM SSTs .. mine and a friend's .. mine got boost cut .. his didn't .. so I think maybe (MAYBE) there's also variations in the amount of turns you get on the production cars too ..
Did you by any chance have an mbc on your car and he didnt on his? The factory boost control system does a pretty good job of preventing boost cut by preventing the boost from spiking too high.
Old Jun 24, 2008 | 06:48 PM
  #116
gunzo's Avatar
TOTALLY STOCK
I'm not a fan of MBC.. very crude plus I like to run multiple settings for street, wife and track ..
As compared recently .. my TOTALLY STOCK (for now) car spiked to 27psi versus my friend's 23 psi .. BUT his tapered to 15-16psi whilst mine tapered to 13-14psi .. This could be due to the boost sensor we use but his upper rpm ranges corresponds to what you guys see here ..
Old Jun 25, 2008 | 07:01 AM
  #117
qubit's Avatar
I believe the mail in flash will raise the boost up as well. So you probably would want to revert this back to stock if you get a flash, since the flash will be tuned for a specific psi. I would assume you will not gain any additional power by doing this mod in addition to a flash. In fact, this mod is probably much more dangerous than with the stock tune.
Remember this mod is about getting a better boost curve, which is all determined by the wastegate on your turbo. the wastegate can be controlled mechanically, via a mbc, or adjusting the wastegate actuator, or it can be done electronically, via the ecu or a ebc. If you've gotten a tune then it's been set electronically via the ecu to have a specific boost curve, this mod shouldn't be necessary.
Old Jun 25, 2008 | 02:36 PM
  #118
trans_lux's Avatar
Cool thanks for the info. Trying to avoid going BOOM!
Getting the AMS flash this week will report back
Old Jun 25, 2008 | 04:23 PM
  #119
love9sick's Avatar
Does the Clevis rotate in the negative position at all? If you loosen the jam nut bolt does it spring or does it just sit there and wait till it is turned? Can it be turned in the opposite direction? I should expect 25 psi and about 18-19 psi taper after full turn? Did you guys drive it fulled turned and give it full load in fifth gear on the high way and lower RPMS? no CEL or SES lights? No boost spikes?
It seems like this mod is better than an MBC because it tapers less boost up on top of the rpms and doesn't throw check engine and SES lights. Right?
Old Jun 25, 2008 | 06:04 PM
  #120
evostang's Avatar
This is what happens in my car. I can't gaurantee every car is exactly the same.
It will rotate in both directions. It is not spring loaded, if you remove the clevis from the actuator while the jam nut it loosened, and you do not turn the clevis by hand, then the clevis just sits there and does nothing.
I got 25-ish psi in fourth gear at WOT at about 4000 RPM. Haven't gotten 25 psi in third or fifth. It seems to taper down to 18-19 psi, on my car, at WOT, between 6000 and 7000 RPM, in third, fourth, and fifth gears.
Yes, that is how my car is set up now. It seems to get to about 15 psi in fifth at low engine speed (2000 - 3000 RPM?, not sure exactly on the range) on the highway. No CEL on my car.
This is why I'm not installing my MBC. Whether or not it's "better" is open to interpretation.
