CBRD wins the least expensive power mod award...
Old Jul 21, 2009 | 11:29 AM
  #211
GsrEviluTionX's Avatar
i tried this and my car is not likeing it... i have a CEL....how do i tighten the aculator am i just moving the lock nut and the other piece up on the threads or am i turning the long silver rod itself?
Old Jul 21, 2009 | 11:33 AM
  #212
DVDee's Avatar
Sounds like you did it wrong. Try putting it back the way it was first and confirm nothing was damaged.
Old Jul 21, 2009 | 12:21 PM
  #213
well i reset the battary car runs fine, just when i acclerate hard a CEL comes on, im askign how do you tighten/ lossen it so i can put it back to the way it was the car alos sounds more grunter.
Old Jul 30, 2009 | 08:39 PM
  #214
mertdinc's Avatar
is this mod applicable to MR's as well. Does anyone know how the transmission responds? Also would adding boost pill with stock wga make this mod better with stock wga boost controller setup. I have read MR's don't like MBC's because of issues with boost control and clutch engagement..
Old Oct 15, 2009 | 11:49 AM
  #215
ImEv0's Avatar
waht is mbc?
Old Oct 15, 2009 | 11:57 AM
  #216
donotswitchoff0's Avatar
manual boost controller
Old May 8, 2010 | 10:05 AM
  #217
scheides's Avatar
EvoM Moderator
Just did this on my new beaterX! 2.5 turns in on the wga and 1/3 down on the MBC yielded this:
Comparator numbers:
http://scheides.com/misc/pics/evox/evoX-wgacrank.JPG
Should have left the MBC alone I guess, peak did go down a tish, but with the mods on the car, 26psi peak is plenty for now:
Lastly, the data, for anyone that cares:
http://scheides.com/misc/pics/evox/E...t-wgacrank.xls
This was done on the same road, same conditions, within an hour of each other. Perfectly flat, started run in 3rd at ~2000rpm and WOT till ~7000.
Old May 23, 2010 | 04:18 PM
  #218
Satori's Avatar
I don't think that counting how many times you turn the arm in is very accurate at all. It seems to me that since not every WGA is adjusted the same from the factory, it might be better to screw it all the way in and then back it off the amount you want.
For instance: for what's called "3.5" turns, might not be for every car so just tighten it all the way then back it off half a turn. Seems like it would be a more accurate way to do it.
Old May 23, 2010 | 04:36 PM
  #219
hotdog's Avatar
Holy. Hell. Zombie. Thread.
Old May 24, 2010 | 07:55 AM
  #220
scheides's Avatar
EvoM Moderator
^Oldie but goodie!
Old May 24, 2010 | 08:10 AM
  #221
Satori's Avatar
It was new to me
mitsuevo803
Jan 21, 2017 06:57 PM
CBRD
Jul 16, 2011 12:45 AM
Blitz
14
May 15, 2011 11:12 AM
CBRD
Aug 25, 2010 07:56 AM
CBRD
Jan 29, 2010 07:42 AM
