Lost boost when I went back to stock BOV?
Old Apr 13, 2009 | 04:24 AM
  #31
gunzo's Avatar
Originally Posted by t12ung
This does NOT work ... I've tried it personally was having problems with this. I was told from Bryan@GST that it induces compressor surge as the bov will not open correctly.
It works .. if you're throwing CEL .. its P1238 .. because the VE torque value now exceeds the calculated value .. and you need to actually reset the value higher ..
Bryan is correct in that you get compressor surge because the current turbo spools so fast after a tune its very bad .. especially at 2500+rpms at 23psi ..
If you're untuned without any mods that increases boost or VE .. then you're actually fine .. you won't run the surgeline so close
Old Dec 9, 2009 | 02:31 PM
  #32
LVSBB6's Avatar
Those running HKS SSQV, how much more boost did you (gain) just by installing it compared to the stock BOV?
Old Dec 9, 2009 | 08:54 PM
  #33
Jonnyblaze81's Avatar
any one got pics of the BOV flipped around?
reggiesd
20
May 11, 2018 02:24 PM
CtSilver03Evo
May 14, 2014 10:47 AM
Pawl7
Mar 2, 2014 09:53 AM
zenoise
Mar 12, 2013 02:52 PM
scothu
Apr 13, 2011 09:18 AM
