Thoughts on a Transfer Case Fluid Change at 15K?
hey just a question. how do i change the fluids in my transfer case? (pictures would be nice also)
AMSOIL SVG 75W-90
And ignore the part about having to bleed the system, that's the procedure for when you change the ACD (or AYC) fluid. The Transfer Case is drain plug, fill plug, done. GL
Here is one i found helpful
GL out there!
Transfer Case:
http://evomoto.com/tech_info.php?tPa...fd561d8c6e7f08
Transmission:
t-case
GL out there!
Transfer Case:
Transmission:
GL out there!
Transfer Case:
Transmission:
What are all the fluids that should be changed in the X?
Engine Oil
Engine Coolant
Brakes
Transmission (also house the front diff or that separate?)
Transfer Case
Rear Diff
Please add anything I'm missing.
Engine Oil
Engine Coolant
Brakes
Transfer Case
Rear Diff
You only need 1 qt to do the t case yourself. Not worth 300 bucks.
If that didn't makes sense, I am completely wasted and I apologixe.... have a nice day.
I used amsoil svg 75 90 for the t case. I used the diaqueen mitsu stuff the first time.
TxFAkuma
May 2, 2016 07:41 PM
Kierkegaard
Apr 10, 2007 07:52 PM
