EVO X FP Red With Supporting Mods
Old Dec 17, 2009 | 08:46 AM
ArchieBabes's Avatar
I am in the process of rebuilding the engine, and will be running E-85
Mods below.
1. FP Red
2. AMS Widemouth 02/Downpipe
3. Cossworth MX1 Cams
4. ACT Heavy Duty Clutch
5. Upper and Lower Intercooler Pipings
6. AGP Intercooler
7. AEM Intake
8. 3 inchTest Pipe and Cat Back Exhaust
9. ARP Head Bolts Set
I talked to my tuner, he said he will put a base map on it just to be safe.
How much whp and wtq should I get on 91 fuel with the above mods?
Old Dec 17, 2009 | 12:43 PM
murlo26's Avatar
Pretty similar to my setup Not sure on 91 fuel though, should still be solid.
Old Dec 17, 2009 | 02:30 PM
mlomker's Avatar
I think the usual answer is: depends on the dyno.
What do you have for fueling? If you are running a single Walbro on E85 then that'll be what limits you next. They max out in the mid-400's on the liberal dynos.
Old Dec 17, 2009 | 02:34 PM
DRAG's Avatar
Arch you said you are switching to E85 but asked what you would make on 91. If you are running 91 I would have stuck with the stock turbo.
Old Dec 17, 2009 | 02:59 PM
RU EVO's Avatar
I think on a dynojet you might be able to see between 410-430whp @ 25-28psi using E85.
Old Dec 17, 2009 | 04:45 PM
danielskshin's Avatar
Did you blow your motor? I saw your car at South Coast.
Old Dec 18, 2009 | 08:09 AM
scheides's Avatar
EvoM Moderator
+1, what happened?
Old Dec 18, 2009 | 08:38 AM
SBR INC's Avatar
you said you were building your engine. What parts did you end up going with? Choosing the right internals is very important on any build like this. Feel free to let me know if I can help answer any questions.
thanks
Marti
Old Dec 18, 2009 | 09:56 AM
Clark_Kent's Avatar
Which shop is handling the tuning?
Oct 18, 2016 12:43 PM
sleeper04
Nov 29, 2010 12:46 AM
ArchieBabes
Evo X Dyno Results
36
May 2, 2010 07:06 AM
Chris@AMS
Evo X Dyno Results
65
Aug 6, 2009 12:58 PM
ch53avitech
26
Dec 19, 2008 02:56 PM
