Breather tanks
Breather tanks
Hey guys, ever used Breather Tanks on your cars? Talked to some friends that has them on their 240sx and what not... says it helps a lot. Would it do the same to our cars? Also, What's the difference between N-type and S-type...
http://www.more-japan.com/home.php?cat=557
Search for 'Oil Catch Cans' - same thing, different names. Basically the air is passed through these cans that contain steel wool, a mesh, or plates to bounce/siphon oil/water out of the air that would normally return to your engine/turbo and gunk it up. <--- description in a nutshell.
For emissions, as well as hazardous materials. By burning it off, your car produces exceptable emissions still, however if people didn't empty their catch cans, they would overflow leaking oil/other garbage to atmosphere. If people did have catch cans to empty, it's even more hazardous materials being disposed, and something that might be an inconvenience to customers. Easy solution? Burn it up and save the trouble to customers.
I had one of these I made from home depot stuff for my srt-4 years ago. worked great till I replaced it with a boomba. didnt bother with one for the x.
edit.... just looked at the site... this is an air separator for your coolant system. never heard of this sorta thing.
There is a big difference between coolant air separator and a coolant overflow reservoir. They are usually used in low flow type coolant systems, like the 2nd gen RX-7.
Not to the extent that cars like the RX-7s do. Our coolant temps don't run that high, 170-190F compared to 210+F like most cars. So it probably doesn't make a significant difference on a Evo X, unlike some other older cars.
Evo47
Feb 16, 2015 05:23 PM
