400hp on stock turbo?
The FMIC dosnt so much add power as it does stop you from losing power. Sure you may pick up a little power do to cooler air and denser air in your combustion chamber. The real gains are stopping the loss of power due to heat soak. The dyno fan just cant replicate 60+ miles an hour wind being forced through your intercooler. Put your hand in front of a fan at any dyno shop. Now stick your hand out the window while driving down the highway. Just a bit of difference. The bigger the intercooler the more heat is removed from your intake charge. A good example of heat soak is seen in the 03-04 Cobra's. My 03 cobra with basic pulley set up and the crappy, tiny stock intercooler would lose up to 50 hp from dyno run 1 to dyno run 3. After installing a bigger intercooler I picked up 5 hp on the first run and only lost 15 hp by run 3.
clip14
Aug 30, 2016 07:18 AM
