S-AWC Service Required Light
Old Jun 4, 2013 | 04:39 AM
  #46
SrT2Evo10's Avatar
Sorry I meant C161E. The pump winds for 7 seconds than stops same speed. Does this mean the pump is bad? Or is it something else....
Old Jun 4, 2013 | 09:18 AM
  #47
Iowa999's Avatar
That's absolutely standard dead-pump behavior. You must replace the pump, rebuild the pump with the parts from Canada, or send the pump out for repair.
I'm sorry for your loss.
Old Jun 4, 2013 | 09:08 PM
  #48
SniperwolF's Avatar
how do you take the pump out? when you do thus oil splatter around??
Old Jun 5, 2013 | 03:25 AM
  #49
mshilto89's Avatar
Its on the passenger side, in the rear, you have to remove the wheel to access it. As far as removing it, I'm not too sure about that.
Old Jun 5, 2013 | 04:53 AM
  #50
SrT2Evo10's Avatar
Is the canada rebuild kit on ebay good? Or is there another place to get it?
Old Jun 5, 2013 | 08:20 AM
  #51
Iowa999's Avatar
Watch the video on rebuilding before attempting. And, yes, they sell their kits on ebay. Nothing should splatter, because there will be no pressure. After all, your pump is dead.
Old Jun 5, 2013 | 10:51 AM
  #52
Ruff-Shaw's Avatar
The kit is solid. I have it in my own pump.
Old Jun 8, 2013 | 09:10 PM
  #53
Iowa999's Avatar
There is now a sticky to report when your pump failed (if you have been so blessed). Please post in it, if your pump has died. Thanks.
Old Mar 2, 2023 | 04:55 AM
  #54
Stewoodbine's Avatar
Originally Posted by xop32
its a common problem on these cars fot the ayc pump to rust up and then not be able to build up pressure
most of the time its not a failure of the pump if you can hear the pump spinning and not stopping until after 7 secounds you no you have this problem
the ayc pump should start spinning build up presure and then slow down, if your pump runs at the same speed after starting up for 7 secounds its probably the cause
if you live in a area with cold weather and salt on the roads, u will encounter this problem for sure
good thing is you can get them rebuilt for alot less than a new one, mine came to £300 rebuilt, where dealers wanted £2000+ for new one
Hi, do you remember where you sent your pump get it rebuilt in the UK? Mine has gone and the price at Mitsubishi is £3100!
thanks
Stewoodbine
Old Mar 3, 2023 | 05:38 AM
  #55
xop32's Avatar
thanks
Stewoodbine
https://hh-ms.com/mitsubishi-acd-acy-pump/
Mitsubishi ACD/ACY Pump - Harry Hockly Motorsport
looks like there still doing it and charging £220 for a pump rebuild
Harry Hockly Motorsport Ltd
Unit 7, Dyffryn Industrial Estate, Pool Rd, Newtown SY16 3BD
moparfan
Oct 29, 2016 12:34 PM
moparfan
Apr 17, 2016 09:22 PM
Brabus55
Mar 7, 2016 02:44 PM
moparfan
Mar 4, 2016 01:55 PM
JDMV8
Nov 24, 2015 08:59 PM
