c161e code
Old Jun 28, 2011 | 08:30 PM
shrekalec86's Avatar
Question c161e code
Just rebuilt my trans and put it back in and this code comes up c161e so I checked and clear and when I drive easy not really getting on the car it dosent throw the code. But when I put thru the paces it will come back could the pump be bad or something loose??
Old Jun 29, 2011 | 06:25 AM
jd888jd's Avatar
Yes your ACD pump is not working the way it should. My buddy had this problem, will cost him $3500 parts and labour to get it fixed. Unless its still under warranty. Unfortunately for him its not covered anymore.
Old Jun 29, 2011 | 08:11 AM
cfdfireman1's Avatar
DTC C161E: Electric Pump Relay Circuit System (Stuck)
CAUTION
If there is any problem in the CAN bus lines, an incorrect diagnostic trouble code may be set. Prior to this diagnosis, diagnose the CAN bus lines.
Whenever the ECU is replaced, ensure that the CAN bus lines are normal.
Since the fluid in the hydraulic unit will be hardened under low temperature, the load of the pump increases and the motor may not operate normally. Therefore, completely remove snow and ice from the hydraulic unit and leave the vehicle under temperature of 0°C (32°F) or higher for 4 hours or more before performing the troubleshooting.
OPERATION
AWC-ECU controls the electric pump by the information from AWC pressure sensor and electric pump relay.
DTC SET CONDITIONS
The code is set when the electric pump operation signal is output from AWC-ECU, and when the AWC pressure sensor signal is not reached the specified pressure after the specified time has elapsed.
PROBABLE CAUSES
Fluid malfunction (low fluid level)
AWC pressure sensor malfunction
Electric pump relay malfunction
Hydraulic unit malfunction
Electric pump malfunction
Damaged harness wires and connectors
Malfunction of AWC-ECU
Used under low temperature condition
Old Jun 29, 2011 | 08:12 AM
DIAGNOSTIC PROCEDURE
STEP 1. Check whether the diagnostic trouble code is reset.
As for vehicles under low temperature condition, carry out the contents of the precautions, and then check the diagnostic trouble code again.
Q: Is diagnosis code No.C161E set?
YES: Go to Step 2.
NO: This diagnosis is complete.
STEP 2. Scan tool CAN bus diagnostics
Using scan tool MB991958, diagnose the CAN bus lines.
Q: Is the check result normal?
YES: Go to Step 4.
NO: Repair the CAN bus lines. After repairing the CAN bus line, go to Step 3.
STEP 3. Check whether the DTC is reset.
Q: Is DTC No. C161E set?
YES: Go to Step 4.
STEP 4. Fluid check
Check that the fluid level is adequate. (See: Transmission and Drivetrain\Differential Assembly\Service and Repair\Procedures\Rear Axle\Fluid Level Check)
YES: Go to Step 5.
NO: Add the fluid. Then go to Step 15.
STEP 5. Scan tool diagnostic trouble code
Check if the AWC diagnostic trouble code No. C1611, C1612, C1625, or C161D is set.(See: Diagnostic Trouble Code Descriptions\S-AWC)
Q: Is the DTC set?
YES: Perform the relevant troubleshooting.
NO: Go to Step 6.
STEP 6. Scan tool actuator test
OK: Operating sound of the electric pump can be heard.
YES: Go to Step 14.
NO: Go to Step 7.
STEP 7. Electric pump relay single unit check
Check the electric pump relay. (See: Transmission and Drivetrain\Transfer Case\Service and Repair\Procedures\Sensor, Switch and Relay)
YES: Go to Step 8.
NO: Replace the electric pump relay. Then go to Step 15.
STEP 8. Electric pump relay connector check: A-26X
YES: Go to Step 9.
NO: Repair the defective connector. Then go to Step 15.
STEP 9. Check the wiring harness between A-26X electric pump relay connector terminal No. 2 and fusible link (35).
Check the power supply line for short or open circuit.
YES: Go to Step 10.
NO: Repair the wiring harness. Then go to Step 15.
STEP 10. Electric pump connector check: F-14
YES: Go to Step 11.
STEP 11. Check the wiring harness between A-26X electric pump relay connector terminal No. 4 and F-14 electric pump connector terminal No. 2.
YES: Go to Step 12.
NO: Check C-21 and D-12 intermediate connectors. When no problem is found, repair the wiring harness. Then go to Step 15.
STEP 12. Check the wiring harness between F-14 electric pump connector terminal No. 1 and body ground.
Check the ground line for open circuit.
YES: Go to Step 13.
STEP 13. Check whether the DTC is reset.
YES: Replace the hydraulic unit. Then go to Step 14.
NO: Intermittent malfunction.
STEP 14. Check whether the DTC is reset.
YES: Replace the AWC-ECU. Then go to Step 15.
STEP 15. Check whether the DTC is reset.
YES: Return to Step 2.
Old Jun 29, 2011 | 01:22 PM
2010XMAN's Avatar
Straight from All Data. Gotta love it!!
Old Dec 17, 2011 | 05:23 PM
wallace989's Avatar
this scares me as i just had my clutch redone now im getting this code
Old Dec 17, 2011 | 05:36 PM
evokid4life's Avatar
Mine threw the same code and it was the pump ended up having it reaplaced by dealer at my cost which was $3000 with labor
good luck
Old Jan 18, 2018 | 07:01 AM
ultm8mind's Avatar
Veteran: Army
CAUTION
OPERATION
DTC SET CONDITIONS
PROBABLE CAUSES
So this could be solely after leaving the car in cold or freezing conditions that this error is occurring?
volksjager
31
Sep 26, 2021 12:18 PM
Sam Lau
Aug 26, 2017 11:52 AM
Sam Lau
Aug 8, 2017 08:19 PM
spam2012
Jun 7, 2017 08:54 AM
xReVoKeDz--
Mar 30, 2016 06:38 PM
