ACD/AYC pump failure reports
Old Dec 15, 2015 | 07:21 AM
  #106
lancevox's Avatar
A little bit OT but can i have an explanation : Evo X RS and GSR (European model) have the same AYC pump ?
Old Dec 25, 2015 | 01:47 AM
  #107
masterkabal's Avatar
Anybody in need of a USDM Evo 9 MR acd pump?
I've got one that was rebuilded 3 months ago.
PM me if your interested.
Old Dec 28, 2015 | 06:03 AM
  #108
Juris Berzkalns's Avatar
year: 2011
first bought: 2014 [November
pump started to fail: 50 000 or so [2015/7
pump failed: 52 000 (8/2015)
cold-start reflashed: chipped
Lancer RA Sportback
Europe, to precise Latvia. Cold winters, hot summers and salt as well..
I'm reading here, that some of you, are getting the thing done by warrantyr, just before 100k, and ai have online 60 000, and they wont do it. its stealership, which do not wants to help, because they think everybody is stupid.
Well, there is the big question, what to do? because dealership told me, that rebuilding it it will like 50/50, which i consider as a chance.
For new they are asking 1.5000 Euros. witch is those 2k dollars.
Maby there is a chance not to use that active differential. Maby there is a one option just tarmac, or just snow, like in the rally cars. I believe they change this thing to improove the results.
Its 4x4, but without that thing, like USDM, JDM and Europes evo's were different.
USDM ones didn't had this differential thing.
Old Dec 28, 2015 | 06:26 AM
  #109
i can only replace the pump with the original and evo X pump, or i can use older evo's pump?
Old Dec 31, 2015 | 10:12 AM
  #110
hoobastnk90's Avatar
Prolly would want to use a pump for the X. Also the warranty should cover it since there was an extension issued by mits for a 10 years or 100k miles.
Old Dec 31, 2015 | 12:05 PM
  #111
evoluutio's Avatar
Here is my solution for the pump issue, about 4 months and 15000km's of hard testing behind. Zero problems.
http://www.ebay.co.uk/itm/Mitsubishi...gAAOSwkZhWSjon
I got also a set of more powerful ACD electric motors (180w), looks almost OEM. These motors will need adapter flanges to evox pump, i haven't had time to do these adapters yet, maybe in 2-3 weeks these motors are ready to go. Price will be somewhere 250$
Old Jan 13, 2016 | 07:10 PM
  #112
Emkay89's Avatar
Pump Just died in my '11 MR. 40k miles Just made the warranty. Anyone get the relocation kit? I know the cold weather didn't help.
Old Mar 29, 2016 | 02:46 PM
  #113
Alkor's Avatar
Year: 2010 (SE)
first sold: 2/2011
pump started to fail: not sure
pump failed: 59,250 (3/24/2016) Made a moaning noise - had to disconnect the battery and after reconnecting I received the "4WD System Service Required"
cold-start reflashed: Never reflashed by dealer. Custom tuned.
Just had my pump replaced via the extended warranty at Fountain Mitsubishi. Incredibly positive experience - mod-friendly and replaced same-day!
Old Mar 29, 2016 | 05:00 PM
  #114
.M.'s Avatar
.M.
year: 2008
first sold: ? (2nd owner)
pump started to fail: 55k (Oct 2015)
pump failed: 56k (Nov 2015)
cold-start reflashed: ? (2nd Owner)
Old Apr 12, 2016 | 01:48 PM
  #115
KVandy15's Avatar
year: 2012
first sold: Jan 2013
Pump started to fail: 40k
Pump failed: 45K
cold-start reflash: unknown, don't think ever.
I have a full suite of bolt-ons and aftermarket tune, I'm well past the bumper to bumper warranty. Mitsu covered the replacement no problem
Old May 18, 2016 | 04:19 AM
  #116
The_X_Effect's Avatar
Year: 2013
First sold:2013
Pump started to fail: 5/14/16 31k
Pump failed: n/a
Cold start reflash: n/a
Full bolt ons e85. Bought the car from a dealership with it molded they had to replace the 5th gear and syncros due to fifth gear grind. Took car home on a Friday next day started the car up and system 4wd service required came on took it back to the dealership and now there stuck replacing that for me to at no charge. Wasn't a Mitsubishi dealership either
Old May 18, 2016 | 05:51 PM
  #117
Firebuck2059's Avatar
Year:2014
First sold: may 2014
29000 KMS
Just got the flashing Tarmac on Monday. Going for code read on Wednesday. Same symptom as with my Ralliart when it went. Will update if other cause.
Old Jun 17, 2016 | 01:38 PM
  #118
tkromer's Avatar
Had 4WD error message about a year ago, took it to the dealer and they flashed it according to whatever TSB and it went away. Last week I noticed that my "tarmac" light would flash and the bar graph was going away on the AWC screen. Yesterday I had the 4WD error message briefly again. Is this likely the ACD pump?
Old Jun 17, 2016 | 06:30 PM
  #119
Pump was failing I forget the actual code but they had to call head office as it was not listed. It would stop working at constant speed. If turning or accelerating/braking the light would stop flashing. Fluid levels were fine. Pump being replaced Monday. At this rate I will have to replace it 3-4 times before warranty is up.
Old Jun 27, 2016 | 06:59 AM
  #120
HatrixMouse's Avatar
Year: 2012
First sold: 10/2011
Pump started to fail: 41,000 miles (02/2016)
Pump failed: 42,000 miles (03/2016)
Cold-start reflashed: No
Location: North East, USA - probable cause; hooning over the winter in the snow.
*Covered under warranty in at Mitsubishi of Oxford in Oxford, PA. Dealership not suggested to use for anything else outside recalls/warranty*
