Brand new clutch issue/ monoloc collar and throwout bearing.
Soooooo, I got a brand new ACT clutch and installed it. Put the transmission back in a noticed that the clutch fork wasn't forward ( pushed towards the passenger side). Indicating that the throwout bearing wasn't locked into the collar so I looked through the peephole on the transmission. Before touching anything because I didn't want to cause any damage. The monoloc collar was pushed out the pressure plate and locked onto the throw out bearing. I've never seen this happen not once. So I pulled the transmission back out so I could inspect it hoping that nothing was damaged and I could just snap the collar back to the pressure plate and give it another go. Wellllll...... the throwout bearing was cracked so I'm not sure what exactly happened or what caused this. I called MAP and let them know what happened and they got in touch with ACT about the clutch. I'm just trying to understand what happened and why the throwout bearing cracked and did not lock into the flywheel.
You can clearly see the ears on the throwout bearing are yanked back. I feel like the pressure plate didn't release and thats the only thing that I can think of at this point.
And the crack inside the throwout bearing.
Did you try to lock in the TOB (pull clutch fork towards driver side) before you tightened the Trans to the engine?
You want to have the trans fully mated to the engine before trying to pop in the TOB to the collar.
Side note, always use OEM TOB. don't try to use another ACT TOB.
No I never locked it in didn't make it that far, I had the transmission all the way bolted up. Like I said at this point I feel like its something that I did that caused it.
Verify that you have all the right parts, its very odd that the center of the TOB broke and the ears bent like that.
Idk what happened, but as stated above you shouldn't be using the ACT TOB, they are junk. Get an OEM piece, check the collar in the pressure plate that the monoloc snaps into for any cracks. If its good, put the monoloc back in the pressure plate, use an OEM TOB and put it back together.
Looks like the fork was behind the "ears" when trans was attached, so bent them when trying to snap the TOB in to place? I only say that because I can't see how the tabs would bend like that while the fork is in place.
weird.
I've never seen such a thing.
+1 on OEM TOBs. I have half a dozen reasons why.
Read the FSM to be 100% everything is being done correctly and triple check your work as you go. Good luck!
weird.
weird.
weird.
😑 After it was bolted down the individual that was helping me the first time. Tried to push the TOB in and broke it when I walked off to go grab an impact. Because the monoloc got knocked out of the pressure plate. Some how when the transmission went back in and hooked on to the TOB when he tried to lock it in. Obviously its probably not going to be able to go back into the pressure plate with the monoloc attached to the damn TOB. Instead of stopping when it wouldn't go in he tried to force it in and just didn't tell me about it.
I've been driving the car for a couple of days now and its running great. I'm pleased with the clutch set up the only issue I'm having now is getting use to how hard it grabs. The second you release the clutch enough for it to catch it grabs. So needless to say I've stalled the car a few times. 🤦♂️ It's not extremely difficult to drive, but I've killed it expecting it to slip a little like my old clutch when letting out. But right now it just doesn't have much give. Lol.
Randal
16
Jul 8, 2014 04:30 PM
Kiartiger
Jun 1, 2012 10:17 PM
Lv"evo8u"
Nov 20, 2004 10:15 PM
