Sponsored by:
Sponsored by: CARiD
Recall for 08-09 Evo X/Ralliart
Old Sep 18, 2009 | 05:04 AM
  #76
dek0026's Avatar
does an aftermarket fuel rail fix this or do we need a whole new fuel return pipe and have it bracketed on differently.
Old Sep 18, 2009 | 05:11 AM
  #77
therocket's Avatar
The problem is on the return fuel line, so ONLY a rail will not solve it. Yes, if you want to go aftermarket you need a set containing not only rail but also return line.
Old Sep 18, 2009 | 07:36 AM
  #78
Clipse3GT's Avatar
The AMS fuel rail comes with a new feed line, which replaces the metal one mounted to the engine.
Old Sep 18, 2009 | 08:31 AM
  #79
Andrew@AMS's Avatar
Yes, the AMS fuel rail does come with the line!!!
**Click Here To View**
Old Sep 18, 2009 | 08:44 AM
  #80
Clipse3GT's Avatar
Old Sep 18, 2009 | 08:58 AM
  #81
DannyK24's Avatar
I could see why this recall was issued. Working on the intake gasket I saw how flimsy these lines were.
Old Sep 18, 2009 | 08:59 AM
  #82
therocket's Avatar
Are you sure that it is the return line? In the specs it says it is feed line
Old Sep 18, 2009 | 09:01 AM
  #83
chidevildog's Avatar
So replacing my stocker with ams resolve this problem? If so this gives me more reason to upgrade with AMS....
*AMS group buy?????
Old Sep 18, 2009 | 09:03 AM
  #84
kenpo1441's Avatar
Originally Posted by xi
hope he had GAP insurance...maybe this will happen to my car.
Old Sep 18, 2009 | 09:04 AM
  #85
Gardo_Segovia's Avatar
Posted Sept 14, 2009
https://www.evolutionm.net/forums/ev...-ralliart.html
with link to the NHTSA as well.
Old Sep 18, 2009 | 09:06 AM
  #86
bump for merge?!
Old Sep 18, 2009 | 09:19 AM
  #87
Clipse3GT's Avatar
There is only one line going to the fuel rail.
Old Sep 18, 2009 | 09:27 AM
  #88
^ clipse i see you got your ams fuel line recently! damn you beat me to it... lol
Old Sep 18, 2009 | 09:50 AM
  #89
Clipse3GT's Avatar
ahead of the game...
Old Sep 18, 2009 | 11:47 AM
  #90
hotdog's Avatar
But there *IS* a fuel return line, correct? Even if it's not directly attached to the fuel rail itself?
I was under the impression the "crack prone" part was the return line, and not the fuel rail feeding line. If you look at the lines running there, you can clearly see two lines: One feeding the rail, which looks snugly attached, and one leading back, beside it. This one sort of "hovers", and is the one I believe they're changing.
