Recall for 08-09 Evo X/Ralliart
This is a return-with system, so there's one line to feed the rail (attached to the right of the rail, looking from the front of the car) and one return line, that comes from the fuel pressure regulator attached on the left side of the rail. This is the part subject to the recall, not the feed line. I think that instead with the AMS rail it comes the FEED line: this is what it seems from the image of the product.
Yeah, thinking about it now, doesn't make a whole lot of sense for an aftermarket fuel rail to come with an added piece for the return line. Seems a bit superfluous.
FWIW, I checked with Buschur, and their Agency Power one does not come with a fuel *return* line.
But there *IS* a fuel return line, correct? Even if it's not directly attached to the fuel rail itself?
I was under the impression the "crack prone" part was the return line, and not the fuel rail feeding line. If you look at the lines running there, you can clearly see two lines: One feeding the rail, which looks snugly attached, and one leading back, beside it. This one sort of "hovers", and is the one I believe they're changing.
Depending on how cool your dealer is maybe you can just order a new fuel return line in terms of warranty, instead of dragging your car in for service and them voiding your warranty or if you have no other choice get rid of the stock metal line and replace it with a high pressure fuel hose or a braided return line.
did anyone get a letter for the hood latch recall I never did, I just happen to be at the stealership when a friend told me about it. I just want to make sure that I get this recall problem fixed.
When did you buy your car?
