Sponsored by:
Sponsored by: CARiD
Can someone tell me
Old Sep 25, 2009 | 08:14 AM
svt04cobra's Avatar
Can someone tell me
If the ichiba stainless steel downpipe causes any codes or issues? Any one on here have this downpipe and how do you like it?
Old Sep 25, 2009 | 11:17 AM
JoeyM3's Avatar
no it will not since there is no cat on it or anything and that o2 sensor just monitors pre-cat emissions
Old Sep 25, 2009 | 11:24 AM
CmakEVOX's Avatar
I have the HKS Downpipe. No codes or problems. I didnt really feel any difference. side by side, they looked the same except the HKS was lighter and shiny.
Old Sep 25, 2009 | 02:01 PM
svt04cobra's Avatar
I talked to Touge Factory who sells this downpipe and test pipe and he said it will throw a cel. They do sell a cel fix that is an elbow that you screw into the dp then screw in the o2. It spaces the o2 away from the pipe which is the cel fix. Now i'm not sure If I need the spacer because both JoeyM3 and CmakEVOX are not having the problem???? Is there anyone who has this DP????
Old Sep 25, 2009 | 03:21 PM
chidevildog's Avatar
hey bro you will throw a code if you test pipe does not come with the cel fix.. so you will get a code period.. if you are just installing the dp then you won't throw a code... hope i that clear some confusion
Old Sep 25, 2009 | 05:36 PM
sonicrx's Avatar
i had thier test pipe and it did not fit right .. i also did not that the part the oem mount goes to is a hole that gets sealed by the bolt that is used for the mount. in my case i just had to put the screw in the hole on the test pipe,as it did not line up with the oem mount.i wound up buying an ams test pipe... the cel fix worked,but the test pipe is poop
Old Sep 25, 2009 | 05:54 PM
JoeyM3's Avatar
the cel fix is for the test pipe, i also bought the touge factory one becuase mine threw 2 cel's with the conventional cel fix, when it didn't have any problems before. but the dp like i said does not throw a cel, a test pipe will if you do not run the cel fix
Old Sep 26, 2009 | 03:14 PM
svt04cobra's Avatar
Cool man thanks for the info yeah I'm just installing the downpipe but for some reason Touge Factory who sells these downpipes said it will throw a code. I'm not sure why it would except the air flow will be increased. Why would he say it would if it won't??? Maybe becasue he sells the fix? Its just an elbow that moves the sensor away from the pipe and allows less air to be passed to the sensor.
Old Sep 27, 2009 | 12:41 PM
LGrady31's Avatar
it will throw a cat code
Old Sep 27, 2009 | 12:48 PM
svt04cobra's Avatar
Do you have this downpipe? Why do others with the X that have change the DP say it won't? I am not replacing the exhaust with a test pipe. This is the pipe from the back of the turbo.
GetFoxed
Dec 12, 2014 11:00 AM
NocturnalEVO
23
Jun 24, 2008 01:08 AM
EvoJoeIX
May 20, 2007 08:29 AM
mexevo
13
Apr 30, 2007 10:05 AM
Carloverx
Mar 15, 2007 06:57 AM
