Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: Install Factory Bluetooth into Evo X GSR
Old Oct 27, 2009 | 12:31 AM
  #211
Optiblue's Avatar
For all u guys that installed the bluetooth, do you have problems where the person on the other end can't really hear you? (mic volume too low)
can't seem to remedy it!
Old Oct 28, 2009 | 02:25 PM
  #212
nelsondevicenci's Avatar
Finally!!
I do my installation on my GTS with GSR steereing wheel, the only problem was to fit properly the switch.
In my experience the bracket of my bluettoth on the GTS steereing wheel help me a lot so i dont used glue just the bracket from my GTS.
Attached Thumbnails HOW TO: Install Factory Bluetooth into Evo X GSR-photo.jpg
Old Dec 29, 2009 | 10:09 AM
  #213
Aseller's Avatar
Thanks OP! I got these parts for Christmas as well as the new covered cup holder and installed it on Sunday. You're write up was spot on and helped A TON! Thank you so much for this wonderful write up! You weren't joking when you said you have to wiggle the steering wheel to get it off those screws! lol
THANKS AGAIN!!!
Old Jan 18, 2010 | 10:39 AM
  #214
emxracer's Avatar
Thanks for taking the time to write this up
Old Feb 21, 2010 | 01:49 PM
  #215
emxracer's Avatar
Figured it out
Old Mar 17, 2010 | 12:57 PM
  #216
EVO X 6950's Avatar
great write up
Old Mar 18, 2010 | 11:59 AM
  #217
EvoXtasy2010's Avatar
NICE write up! How much was total price of parts for everything? I know it will vary a bit, but ballpark?!
Old Mar 18, 2010 | 03:00 PM
  #218
beetle_orange's Avatar
you would be looking at around $400.
Old Apr 12, 2010 | 12:28 AM
  #219
GSXR's Avatar
Ok, so I installed the bluetooth module and the microphone first and thought I would be able to get away without installing the steering wheel buttons for the bluetooth. Well that didn't work. I bought the steering wheel buttons and hooked it up but still couldn't get the BT to sync up.
Stumped, I read the post carefully and found that switching the controls for the AWC to the steering wheel controls was what was needed. I switched the wires for the pin outs and it worked.
Thanks Antic22!
Old Apr 12, 2010 | 01:53 AM
  #220
EndlessRed's Avatar
Thanks Antic22!
there's a reason why you should always read long DIYs thoroughly before starting.
Old Apr 12, 2010 | 07:22 AM
  #221
GSXR's Avatar
Well, my situation was a little different. I didn't install the steering wheel controls so I skipped that portion. Actually, I think it's a good tip. A lot of people had trouble with setting up their Bluetooth and this could be the reason.
Old Apr 16, 2010 | 10:18 AM
  #222
pips's Avatar
Originally Posted by antics22
Thanks for the compliments. The AWC is controlled here now...
This actually works out better, because when the switch was on the steering wheel, it was easy to hit it by accident during turns.... Now, the steering wheel controls are all flush and I get to control my radio on the left, and my cruise on the right....
I couldnt agree more...I'm always hitting my AWC switch on the wheel. I think I'll re-locate it just to get it off of there
Old Apr 23, 2010 | 02:31 PM
  #223
Aseller's Avatar
I would like to relocare the headlight adjustment and the ASC button next to the AWC button in the center... is this easy, or is there any easy way to do this?
Old May 29, 2010 | 10:45 PM
  #224
scorpeus401's Avatar
So I am currently trying to rewire the pins but am having trouble pulling out the black harness itself from the center console. In order to remove the black harness from the center console, do I just pull up? or do I push it forward toward the shift knob, or backward away from the shift knob?
It feels like it'll snap off, I just want to make sure I unhook this properly so i can get better access to the wire pins.
Old May 31, 2010 | 02:18 PM
  #225
So a word of advice, slide a thin screw driver between the black harness and the plastic that attaches the the harness from behind where the wires are showing and then push forward (you can't just push forward since there is kind of a tooth on the plastic attaching the black harness that prevents just pushing forward, hence the reason a small thin screwdriver is needed to slide through to push the black harness up slightly). Wish I had known this beforehand, I ended up pulling up and snapping a bit of the plastic off of the black harness, but was able to get it out and the pin removal was easy. Now my bluetooth works finally.
