Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: Install Factory Bluetooth into Evo X GSR
Old Feb 20, 2009 | 12:00 AM
  #151
mooserov's Avatar
Originally Posted by stockgts09
i went to the dealer today to activate it, as i seasd on my previous post i don't have a navi. to cut the story short, the dealer was unable to activate it because i don't have the audio steering controls and AWC transferred to center console.
Is this true? It sucks as well coz i still have to be charged $70 for hooking up their MUT Scanner.
I don't believe that. My audio controls and awc worked, just not the bluetooth.
Old Feb 20, 2009 | 12:58 PM
  #152
GoKimiGO's Avatar
Originally Posted by beetle_orange
^you might want to check with mitsubishiparts.net cuz i just did some comparison on prices and you can save quite a bit with mitsubishiparts.net
I did the math of sh*ts and giggles and mitsubishiparts.net would save me $2.25 with shipping, LOL.
I will be ordering my kit from them non the less as I trust them as a vendor
Old Feb 20, 2009 | 05:39 PM
  #153
MY08GSRX's Avatar
do we have any way to check if the module is defective or not?
Old Feb 20, 2009 | 09:10 PM
  #154
SethWillits's Avatar
I'm just about to get a GSR (the one positive about this economy is 0% financing), and Bluetooth is a requirement for me, so one way or another I'll be doing this. Like some others here, however, I'd like to keep the change holder and stick the AWC button next to the ASC button to the left of the steering wheel.
I've read this entire thread (it took quite a while), and it seems simple enough, but it'd be great if someone could post some photos with annotations about how they did the splicing to stick the button in that location. It's just not quite crystal clear how it'd be done.
Old Feb 21, 2009 | 02:42 PM
  #155
mooserov's Avatar
I moved the button next to the asc button. I didn't take pictures, but you don't need pictures. Cut the harness that plugs into the center console AWC module, leaving 2 or 3 inches of wire on the plug end. Now you have a plug with 4 different color wires, and a harness with the same 4 colors ( you just cut) You can solder and heat shrink any 4 wires and match them to the same wires on the plug. I used 4 wire telephone cable. You can actually use crimp-type or Butts terminals if you don't want to mess with soldering and heat shrinking. Crimp type connectors are just fine, and in some cases superior to soldering. Just tape everything up to keep it neat.
Old Feb 21, 2009 | 03:23 PM
  #156
THEMEMPHISFORCE's Avatar
When you did this I am assuming you also just moved the correct two wires to the correct two pins? Also did you have to take your steering wheel OFF in order to just add the Audio switch on the steering wheel, no bluetooth?
Old Feb 26, 2009 | 12:06 PM
  #157
Sweet. A new octane blue GSR has been acquired!
Hopefully I'll get around to installing the new controls soon.
Old Mar 1, 2009 | 10:14 AM
  #158
robh's Avatar
This was one of the first mods i did to my car months ago prob the one i use the most also
but i have a couple of questions for everyone that has done this my phone just seems to randomly unsync with the bluetooth module and every so often when i push the up volume on the steering wheel the volume will go down instead of up! anyone have this happen??
If anyone knows any thing i can try let me know thx
Old Mar 1, 2009 | 02:17 PM
  #159
c_reber's Avatar
Yes, steering wheel has to be removed for just the audio controls only. But its a suprisingly simple job with the help of this thread and pictures.
Old Mar 1, 2009 | 03:20 PM
  #160
beetle_orange's Avatar
what i want to know is for those who have done this mod, do you properly retorque the steering nut or just tighten it as much as you can.
Old Mar 1, 2009 | 03:49 PM
  #161
c_reber's Avatar
Torque wrench, what's that? LOL No, I didn't retorque mine, just tightened it by hand. Stayed on so far!
Old Mar 1, 2009 | 06:39 PM
  #162
Frankiago's Avatar
Didn't I read its spec is 33 +/- 8 ft-lbs?
Yep:
Originally Posted by jacksontw60
The spec 33 +or - 8 ft lb
I set my to 33 ft lb
jacksontw60
Old Mar 3, 2009 | 08:09 PM
  #163
rdebow's Avatar
Has anyone had a dealer move the audio controls to the steering wheel and move the AWC button to the center console?
If so did they have an idea already on how to do it, once you told them what you wanted? Or did you have to explain or provide them information about do it including how to change the center console wires for the AWC switch and audio controls on the steering wheel to work properly.
Thanks.
Old Mar 3, 2009 | 08:28 PM
  #164
MY08GSRX's Avatar
south coast mitsu in costa mesa knows how to but they are charging a lot of money......
Old Mar 22, 2009 | 12:57 AM
  #165
eville_stu's Avatar
Installed today
Installed the Bluetooth module and Ipod connector, took about 4 hours. Toughest thing for me was moving the wires around. Had to study the connector and prod around a bit to figure out how to release the wires with damaging the plug. Only issue I had was forgetting to mark the steering wheel position before removing it, so when I put it back on I had to do a test drive to get it straight. Its great having the volume controls on the steering wheel. Now I just need to find the time to go to the dealer and get the Bluetooth module activated.
The photos and instructions were great, thanks again!!!
