replace stock air intake w/ cone style
Whick universal filter from HKS did you buy? The part number would be great. There are 3 different sized inlets, so I need to know which one you got. The 3" coupler fits on the MAF inlet and the 3 1/2" size fits on the hks filter plastic housing, correct? Have you completed the install? If so, can you give some pictures?
Brian
Brian
ok, i'm an idiot. i bought the HKS filter that was too large for the piping. I just bought another filter thats 70mm and it fits perfectly!
HKS filter has to be 70mm with a 3inch coupler FYI!
Oddly enough the Japaness companies list there stuff with respect to I.D. not O.D. like in America. So the 70mm dimension is actually the inside diameter of the pipe plus the two walls of rought 3 mm thickness = ~76mm or 3" o.d. Did you get it installed with the new filter yet? Got any pictures? and P/N of the filter you got?
Brian
Brian
