Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
replace stock air intake w/ cone style
Old Apr 11, 2009 | 04:09 PM
  #166
flacidcore1982's Avatar
intake for lancer 2008
has anyone built there own intake via autozone or any other place like that for the lancer 2008/09?
Old Aug 28, 2009 | 06:39 PM
  #167
krackerstache's Avatar
I'm having some trouble getting the two bolts that connect the air box and the mass air flow sensor
did anyone have the same problem as me??
Thanks
Old Aug 29, 2009 | 01:42 PM
  #168
cmunro's Avatar
Old Sep 11, 2009 | 08:50 AM
  #169
idanno's Avatar
I did this mod in about a half hour, one of my plastic rivet screws was stripped so i had to yank it out, so there's no goin back for me. but, i love the obnoxious spool up and blow off now.
i have an autocross this weekend, i'll post a link to some vids, you'll be able to compare the sound from before and after from a car mounted cam.
peace, danno
Old Sep 19, 2009 | 05:38 PM
  #170
rivz's Avatar
For people in the future here is the how to on how to remove a stuck bolt, https://www.evolutionm.net/forums/ev...t-problem.html
Old Sep 20, 2009 | 10:26 AM
  #171
stikllr13's Avatar
lol back when I got my tune I also had the Cobb intake installed and we ran into the spinning screw problem to. But we where in a rush to get it installed so we could start tuning. So we just eventually cut the screws off lol. I guess that ^^ would have worked too
Old Sep 20, 2009 | 12:22 PM
  #172
wiretap's Avatar
I just did this mod with the K&N filter. The install went smooth, about 10 minutes.
I did encounter one of the "spinning bolts" on one side of the MAF tube. I just took that tube out and used a screw driver to work my way underneath the washer of the spinning bolt. Then I popped it up out of the housing. All you have to do then is just superglue the pieces back into place and it's as good as new when you want to put the stock air box back on.
But HOLY CRAP the turbo spool and recirc valve is loud now. I just started laughing when I heard how loud it was. It rivals most F-350's. The recirc valve actually sounds like a blow off valve too. It could get a little obnoxious, but it's a nice change from the near silence of the stock intake.
I found the K&N 0930 filter at Advance Auto Parts for $45. It was well worth it. I can tell a slight increase in acceleration, but it's not a night and day difference.
Old Sep 22, 2009 | 07:56 AM
  #173
idanno's Avatar
here's a link to an article explaining what's actually happening when you replace the stock air intake.
http://www.cobbtuning.com/info/?ID=3223
one problem i can see having done this mod on the quick, is the fact that the filter is most likely bouncing around on the bushings that used to hold up the old intake duct. This would cause turbulence on the mass air filter, and cause unpredictable results in performance. also, if your air filter is resting at too much of an angle from the MAF you may have constant turbulence. i just ordered an AMS intake because i'm not comfortable with the way my filter is set up, the AMS intake will be nicely mounted with a heat shield, and it includes a new MAF housing that minimized turbulence. hopefully it's not any bigger than the original housing, as per the article above.
here's a video of my last autocross race, http://www.youtube.com/watch?v=x8xYX7ytnfk, this is with the cone filter.
Old Sep 22, 2009 | 07:57 AM
  #174
idanno's Avatar
if you tuned for the new intake, you may see a more marked increase.
Old Sep 26, 2009 | 05:07 AM
  #175
H8ted1488's Avatar
Does anyone know the part number for the AEM dryflow universal cone filter that will work? I'm thinking the 21-203D will work but I want to run it by the experts before I purchase. Thanks
Old Dec 14, 2010 | 01:42 PM
  #176
LIcz4's Avatar
hey! just did this mod and its real easy, and surprisingly i didnt have the spinning bolt issue at all! car is an 08 but only 20k on it so thats probably why.. didnt reset the ecu with the battery disconnect yet but when i get the time ill see if it really helps on the buttdyno. lol but the sound is amazing!! i used to hear the spooling with just my muffler and stock airbox but this sounds awesome and you can easily hear it outside if you drive by. and the recirc sounds legit! more mods to come!!!!
Old Dec 14, 2010 | 02:06 PM
  #177
mksevo's Avatar
Glad you enjoyed it. it was a nice simple mod and likely worth a few ponies somewhere looking at how restrictive the box is. but the sound is worth the mod alone.
Old Aug 31, 2011 | 08:34 AM
  #178
ezzcoke's Avatar
hi all, just need help from the pro..
is "cobb sf intake filter" same as any k&n cone air filter?
if i installed the k&n cone air filter, what ap map should i be using?
Old Aug 31, 2011 | 07:01 PM
  #179
Noe18's Avatar
any dyno sheet yet?
Old Nov 15, 2011 | 03:34 PM
  #180
evo11mr's Avatar
anybody with writeup or comparison of available intakes?
03chi-town0Z
41
Jan 2, 2014 05:04 PM
xwwgsr
12
Aug 25, 2011 09:37 AM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
16
Sep 7, 2009 08:04 AM
EvoX-LI
16
Aug 28, 2009 02:55 PM
cij911
Dec 12, 2006 02:55 PM
