Want to eliminate your MAF?
Old Oct 14, 2005 | 02:54 PM
  #196
dryad001's Avatar
Originally Posted by TurboBob
The Translator Pro will replace the MAF with Speed Density.
You need the Translator Pro
Plug-and-play Speed Density harness
MAP sensor
IAT sensor
It has been done with the UTEC.
Bob
Thats all I wanted to hear. Bob please PM me when the PNP harnesses are out.
Old Oct 14, 2005 | 03:01 PM
  #197
Nez136's Avatar
uh oh!
Old Oct 16, 2005 | 05:06 PM
  #198
joeymia's Avatar
Hey guys I am back from Orlando. I had a great trip car ran perfect. I also had a blast at Universal Studios on Saturday. On Friday afternoon I went to CFT so that could put my car on the dyno. Jestr also came by to flash my car so we could remove the limiters etc. He also fixed the timing with his flash. He played with the MAFT Pro and fixed some of the tipin and made the car idle solid like stock Well here are the numbers:
This was at 22 psi with no meth or race gas This was also from the last run of the night so the car was hot. I am very happy with my results
Old Oct 16, 2005 | 05:32 PM
  #199
EvoTech's Avatar
Nice numbers. Did you have the car dynoed before the MAF T pro? Can you feel a difference without the MAF running speed density. Tell us more please
Old Oct 16, 2005 | 05:54 PM
  #200
joeymia's Avatar
I did 310 on a dyno jet before. I had a boost leak so those numbers were low. The car feels smoother and the power is amazing
Old Oct 16, 2005 | 06:06 PM
  #201
sleet's Avatar
Nice numbers, I was at Halloween Horror Nights on Saturday too
Old Oct 16, 2005 | 06:39 PM
  #202
joeymia's Avatar
use this thread for questions etc.. from now on please.
https://www.evolutionm.net/forums/sh...d.php?t=164487
I am not longer a UTEC user so I don't feel we should consider discusing this here.
Old Oct 17, 2005 | 08:55 AM
  #203
Nez136's Avatar
ok joey im happy everything worked out for you, but there is still the sum of us running the Utec who really want this to work.... i want to know if it will work right soon b/c im going to be making some purchases this month. i don't wan't to buy it and have the same problems with the car running lean until i remove the Utec, i have tuned other devices and the Utec is my Fav b/c all the options that are available (rev limit, boost limit, launch control, Optional solnoids, TIMING CONTROL, ect, ect.) So Bob or whoever let us know when it will work right with the Utec...please!!
Old Oct 17, 2005 | 09:34 AM
  #204
joeymia's Avatar
i was running lean because i did not set it up correctly I believe Bob has this fixed with the file I was not able to load. I think Jack may be getting a unit soon as well
Old Oct 17, 2005 | 09:36 AM
  #205
Nez136's Avatar
i love you joey.
Old Oct 17, 2005 | 09:39 AM
  #206
TurboBob's Avatar
The unit works well, UTEC or not. What it provides is an electronic replacement for the MAF, and a very user friendly way to tune your fuel delivery. The unit has full closed loop boost control, and closed loop AFR control at WOT using a wideband signal. The AUX trigger input allows changing the tune based on a switched input for alky injection etc.
Timing control is in the works, I will post when it is available.
Bob
Old Oct 18, 2005 | 06:38 PM
  #207
EvoTech's Avatar
Bob
If you really want to see the potential of this unit in conjunction with the UTEC then work out a deal with MalibuJack to do some testing. No one will bring out the true potential of this combination better.
Old Oct 18, 2005 | 07:05 PM
  #208
MalibuJack's Avatar
I do plan on getting my hands on a unit sooner or later.. Funds for me are tight because I'm moving into my new house in a few weeks and closing on it at the end of the month.
Old Oct 18, 2005 | 07:33 PM
  #209
TurboBob's Avatar
MJ and I are talking...... have no fear guys.
He wants the analog MAF input function which isn't done yet, but will be very soon.
Bob
Old Oct 18, 2005 | 07:55 PM
  #210
dryad001's Avatar
How about the PNP harness?
