Want to eliminate your MAF?
Old Oct 19, 2005 | 12:11 PM
  #226
TurboBob's Avatar
I am working it....
Old Oct 19, 2005 | 12:14 PM
  #227
TurboBob's Avatar
Originally Posted by GraphiteMR
Just FYI those with the AEM map sensor, TurboBob is currently working out the calibration for the 3.5bar sensor vs. the 3bar GM unit. Bob, can you comment on when this calibration option will be completed?
done.
The software currently supports:
GM 3 bar
AEM 3.5 bar
AEM 5 bar
GM 2 bar
Motorola 2.5 bar
Bob
Old Oct 19, 2005 | 12:16 PM
  #228
GraphiteMR's Avatar
Bob is the man.... In the meantime the knocklink and bosch sensor voltage logger I have rigged up along with monitoring timing should do the trick.
This unit sounds like it will be the missing link...
*edit
done.
GM 3 bar
AEM 3.5 bar
AEM 5 bar
GM 2 bar
Motorola 2.5 bar
Bob
Wow, you are good. It was just yesterday I was told it wasn't ready. Now are these updates available via firmware update from a downloadable file from your site as things progress such as timing control, knock logging and now map sensor calibration files?
  #229
TurboBob's Avatar
Originally Posted by joeymia
The universal harness is as PNP as it gets.
We are working with Boomslang to get a plug-and-play for the ECU connections.
I'm not sure how popular it will be, since the install is pretty easy the regular way. But guys always ask for it, so it will happen soon.
Bob
Old Oct 19, 2005 | 12:22 PM
  #230
joeymia's Avatar
Originally Posted by EvoTech
You should talk to the developers about incorporating that feature. As you know, it is an important one.
bob knows
Old Oct 19, 2005 | 12:23 PM
  #231
joeymia's Avatar
show you support for a MAFTpro subforum!!!
https://www.evolutionm.net/forums/sh...d.php?t=165032
Old Oct 19, 2005 | 12:27 PM
  #232
TurboBob's Avatar
*edit
The MAP sensors and other stuff are part of version 4.2 (which Joey is running) that we have been finishing up. I emailed the stuff to Joey, he updated his unit.
The software is ready to release, software updates will be posted over at full throttle. They are free.
As always, development continues. Keep the good ideas coming, that's how this stuff works.
Bob
Old Oct 19, 2005 | 12:32 PM
  #233
Nez136's Avatar
bob is the Shiat!
Old Oct 19, 2005 | 01:42 PM
  #234
MalibuJack's Avatar
Bob
I have a few ideas, But I want to work with a unit up close for a little while before I make any suggestions since I want to know its existing features first.
I think people are forgetting that this tool can be used by itself, or in conjunction with a reflash, UTEC, XEDE, anything that works with the stock MAF.
There is one thing that should be pointed out. The UTEC is the only device that overrides the stock limitations in the ECU since it directly controls fuel and timing, with the exception of a reflash or full standalone, so just bolting up the MAFTPro won't eliminate things like fuel cut or RPM limits in a bone stock ECU.. The easiest solution is to get a base reflash for the features you need..
Therefore I feel the Maftpro is as great addition to the UTEC, or any other piggyback/reflash solution.. It just happens to be that once the timing features become available, it can be used in place of many piggyback devices such as the s-afc, Emanage, etc. that function in a similar manner (MAF offset and CAS offset) plus you get boost control.
Old Oct 19, 2005 | 01:49 PM
  #235
joeymia's Avatar
Yup a reflash is a must. On the way to Orlando to get the flash I hit fuel cut comming out of a toll plaza. I was running lean at 11.2 and still hit it pretty fast in 4th gear. It scared the crap out of my girlfriend
Old Oct 19, 2005 | 01:57 PM
  #236
GraphiteMR's Avatar
Explain to me how 11.2a/f was lean? Not trying to be smart here, honest question.
Old Oct 19, 2005 | 02:16 PM
  #237
TurboBob's Avatar
you can eliminate fuel cut without the reflash by oversizing the injectors....
If you want to run leaner, you can boost higher without the fuel cut as well.
But a reflash is a good idea anyway in the long run.
Bob
Old Oct 19, 2005 | 02:20 PM
  #238
Nez136's Avatar
Bob, i'll prob. order this next week, will the software be included then? what about the PNP harness?
Old Oct 19, 2005 | 02:35 PM
  #239
joeymia's Avatar
because stock is at the 10's hehe.
Old Oct 19, 2005 | 02:38 PM
  #240
GraphiteMR's Avatar
In relation to stock 10.5-10.6 a/f, but not in tuning.
11.2-11.3 = most flash tuners target to allow for variations.
11.5 is what most people tune to including myself on pump.
11.7-11.8 is what I have seen on some agressive reflashes from tuners names withheld, which may have had some knock.
