Want to eliminate your MAF?
Old Oct 12, 2005 | 07:57 PM
  #76
Matthew333's Avatar
any pics yet????
  #77
joeymia's Avatar
Ok I have everything but the IAT, BARO Singal, and EGRT connections connected. Are all 3 needed? I have no idea which pins they go to on the Evo wiring harness. Also it says to splice cables from the 6 pin connecter. Is this correct?
Old Oct 12, 2005 | 08:00 PM
  #78
TurboBob's Avatar
I don't believe the EVO has EGRT, Thats an OBD-I deal for the DSM's. You don't need it. Baro and IAT are in the 6 pin harness, and the 10 pin.
The ECU pins can be found here:
http://www.roadraceengineering.com/e...-ecuwiring.htm
Many things to RoadRaceEngineering for putting this up.
Bob
Old Oct 12, 2005 | 08:03 PM
  #79
joeymia's Avatar
Bob
ok thanks connecting those now.
Old Oct 12, 2005 | 08:26 PM
  #80
TurboBob's Avatar
Bob
I should proof-read my posts....
Many thanks to RRE.
Old Oct 12, 2005 | 08:48 PM
  #81
TurboBob's Avatar
When you get it in, we need to go thru the setup stuff.....
Drop me a PM or email
B
Old Oct 12, 2005 | 08:49 PM
  #82
joeymia's Avatar
Bob read your PM. I got a new ISP and I don't know the outgoing mail server. I can't reply to your messages I can log with UTEC.
Old Oct 12, 2005 | 08:59 PM
  #83
TurboBob's Avatar
its probably mail.bellsouth.net
you can hit me up on AIM if you like.
The UTEC doesn't log the ECU as far as I know. Tuning anything without knowing what the trims are doing is a shot in the dark.
Bob
Old Oct 12, 2005 | 09:58 PM
  #84
joeymia's Avatar
I got maftpro installed now I just need to troubleshoot with bob the fuel trims etc... Tomorrow afternoon i'll probally have some good results to show
Old Oct 13, 2005 | 07:23 AM
  #85
joeymia's Avatar
Bob I reflashed the unit with the new update. Set a few settings and got the car started. Its out of the garage I am going to try to locate a scan tool so we can read the fuel trims. Give me a call whenever.
Old Oct 13, 2005 | 08:11 AM
  #86
joeymia's Avatar
Here are some pictures of work in the progress. It a freaking mess but I am not close to being done. Also the upper IC pipe will get welded, I don't have a welder nor know how to weld aluminum
Old Oct 13, 2005 | 08:14 AM
  #87
Nez136's Avatar
happy day, no MAF! hopefully it all works great!! its not to easy to weld aluminum(so i've heard). did you guys say that there is a harness in the works for the Evo?
Old Oct 13, 2005 | 08:28 AM
  #88
dryad001's Avatar
You have the alky boost switch in the exact same spot as I do. OT here but where did you tap into? I can't find a decent spot anywhere.
Your car looks like mine on the inside, wires are everywhere.
Old Oct 13, 2005 | 08:33 AM
  #89
joeymia's Avatar
it doesn't need a special harness actually. I am using their univeral kit and it works fine. If you have installed an AFC before its the same thing. They just need create a wiring chart to make it a little easier for other people. Only mistake I did was I did the wires for BARO and IAT wrong. I cut the cables in the 6 pin connector like it showed for a 1g but I did not have to do that.
Old Oct 13, 2005 | 08:34 AM
  #90
joeymia's Avatar
Someone needs to make a bigger cover for under the glove box. I have so much crap dangling out the bottom
