Want to eliminate your MAF?
Old Oct 13, 2005 | 10:58 AM
  #106
joeymia's Avatar
Originally Posted by TurboBob
Actually that feature is already in the software,. The Aux fuel settings are engaged when the purple wire in the speed-density (6 pin) harness is energized. There is an entry in the AFR tracking page to shift the target AFR when that input is activated as well...
IAT sensor is 3/8" NPT, its a GM standard sensor.
Bob
ohhh i know where those settings are !! thanks bob. I just drove the car to mcdonalds in traffic and having to wait the line etc... This thing is running so much smoother now. I used to get this annoying stumble before that I could never get rid of with UTEC. Its gone now... There is no hesitation when I go WOT just a nice smooth transition. I'll play with timing etc.. later when it cools down outside. Sitting in my car with a laptop on my lap, no AC and miami heat = a ****ing oven!
Old Oct 13, 2005 | 11:00 AM
  #107
joeymia's Avatar
Originally Posted by dryad001
That idea will mostly likey work better with non-UTEC, Xede, etc piggybacks. The map switch should do the same job. Figuring that timing is more advanced with alky/meth than a regular map. My meth/alky map is completely different than my 93oct map. This might be the end all to flashes as well as soon as their timing control comes out, might even hamper piggyback sales as well.
Anyone who buys a SAFC or DTEC at this point is insane. This thing is amazing. The low/mid/high throtle fuel maps are intialzed but boost preasure not TPS. If you ever setup a SAFC you know that TPS is not always the best way to switch between low/high fuel maps.
Old Oct 13, 2005 | 11:01 AM
  #108
Nez136's Avatar
hmm, this sounds like a kick *** deal!!!! Bob, when can we jump on the bandwagon!?
Old Oct 13, 2005 | 11:13 AM
  #109
dryad001's Avatar
I remember the AFC stumble, ahh yes many moons ago. So the entire system is pretty much run off of the MAP sensor, right? Any calibrating the MAP sensor?
Old Oct 13, 2005 | 11:19 AM
  #110
Matthew333's Avatar
by eliminating maf, you should be able to push the 500 to 600 hp limit, correct???
Old Oct 13, 2005 | 11:20 AM
  #111
Nez136's Avatar
oooooohhhh yeaeaaaaa
Old Oct 13, 2005 | 11:47 AM
  #112
evovr4's Avatar
so how does it work,do we need the utec for it or its just another piggy back system.
Old Oct 13, 2005 | 12:23 PM
  #113
dsm95hybrid's Avatar
Is there anyone running SAFCII + the MAFT?
Old Oct 13, 2005 | 12:49 PM
  #114
dryad001's Avatar
Evovr4- you don't need a piggyback
dsm95- you can control fueling with the MAF pro, you wont need an AFC.
Old Oct 13, 2005 | 12:57 PM
  #115
joeymia's Avatar
MAFT is a AFC. I don't think you could run them both togther reliably. Besides the MAFT is much more superior than SAFCII. Its has target AFR !!! It also has a ton more fuel trims you can edit.
Old Oct 13, 2005 | 12:58 PM
  #116
but will energizing the purple wire, switch timing maps and have an ability to control boost on a new setting also as in 21 to 28psi?
Old Oct 13, 2005 | 01:01 PM
  #117
three pulls and I can tune the SAFCII to precision accuracy. Probably close to as fast as the targeter. I am already tuning the safcII on MAP utilizing the AEM/Zeitronix 3.5bar MAP sensor.
  #118
joeymia's Avatar
I am having problems getting this to play nice with UTEC. One problem is that UTEC bases load on the amount of air comming in. Since MAFT modifies the MAF Hz they already read low when utec gets them. The next problem is that UTEC wants to lean the car out. Even at 0 all across UTEC will lean the engine out which it shouldn't since its already lean! I even added +20 fuel all over and still to lean. Is there someway I can put in a MAF correction in UTEC or maybe just disable its fuel control for now?
Old Oct 13, 2005 | 01:02 PM
  #119
joeymia's Avatar
you eliminated your MAF with the Safc?
  #120
Full Throttle's Avatar
The MAFT Pro has far more adjustment than the SAFC, 3 load levels vs 2, Boost vs TPS, + or - 60% in 1/2% steps, 14 rpm bands, Pluse wide band, Boost controller, blah, blah
Mike
