Want to eliminate your MAF?
Old Oct 13, 2005 | 09:11 AM
  #91
joeymia's Avatar
Hey bob I got the car idleling fine and got it on the road already Only problem the car stumbles a bit when I let off the gas. But everything seems to be working fine
Old Oct 13, 2005 | 09:18 AM
  #92
EvoTech's Avatar
Originally Posted by EvoTech
Please keep us posted and take pics of the install if you can. I have to give major props to Malibuack for being the first to venture into this territory, but I do think that this setup is an improvement. If this works out it will be freakin great!! The option of switching between speed density or blowthrough MAF is just crazy. I would use speed density in the summer and Blowthrough in the winter for cold starts. While using speed density, I would ditch the MAF alltogether to remove the restriction. It kills me that Turbo XS could theoretically do the same thing through a software only upgrade to the Utec.
Just needed to say it again.
Old Oct 13, 2005 | 09:23 AM
  #93
joeymia's Avatar
umm holy **** this works !!! hehe just ran a few times at WOT. The AFR tracking works. Once it kicked in it kept the car at my desired AFR which is 11.4. Only problem is with tip-in acceleration and stumbles when starting off. That is easily fixed tho. Right now btw I am running on MAP0.
Old Oct 13, 2005 | 09:29 AM
  #94
joeymia's Avatar
well battery on the laptop is low and I am hungry so am going to take a break. bob call me
Old Oct 13, 2005 | 09:34 AM
  #95
TurboBob's Avatar
Ok, going to call.
I would have called earlier, but it looked like I would only slow you down....
Bob
Old Oct 13, 2005 | 09:43 AM
  #96
joeymia's Avatar
crap i am going to pm you another phone number. I forgot to pay the bill on my new cell phone it seems.
Old Oct 13, 2005 | 09:46 AM
  #97
NoTec's Avatar
Old Oct 13, 2005 | 09:52 AM
  #98
Nez136's Avatar
so are you going to still do most of you tuning through the Utec and just let the the AFR tracking do its job or whats the deal, is it going to be lots of work to get them to work together?
Old Oct 13, 2005 | 10:14 AM
  #99
dryad001's Avatar
Hey Bob us with larger injectors how will we compensate for this? Fuel trims?
Good job so far joey, keep up the good work for us.
I am outside for the rest of the morning, tidying up the meth injection so I won't have any problems installing this when I order one when the PNP harness is avaliable, wiring is not my strong point.
Old Oct 13, 2005 | 10:17 AM
  #100
Nez136's Avatar
I can tell
Old Oct 13, 2005 | 10:26 AM
  #101
joeymia's Avatar
I am going to setup the AFR on the MAFTpro as close to stock as possible (rich). Then I plan on still using UTEC for the AFR/Timing. Bob has plans to include a switch so you switch between a race/meth map and a normal map. Once that is done I will probally use MAFTpro for AFR with the target AFR etc... I am going to go get lunch and wait for the heat to go down a bit then i'll do some more tuning. For now the car is running great.
Old Oct 13, 2005 | 10:33 AM
  #102
joeymia's Avatar
For those interested in purchasing this you need to order the following:
M A F Translator PRO
GM Air Temp sensor for MAFT PRO
Gm 3 Bar Map Sensor
36" air temp extension
Universal Speed Density harness 6 ft.
There is no need for a PNP harness etc... You might want to give Bob a week to finalize the software updates for the EVO. He sent me a file to flash the MAFTpro but its not a production file. It works for me but I did some tweaking to the config. If your not to familar with these kind of things just wait for him to release the updated flash.
You can find all that stuff at http://www.fullthrottlespeed.com/
  #103
dryad001's Avatar
That idea will mostly likey work better with non-UTEC, Xede, etc piggybacks. The map switch should do the same job. Figuring that timing is more advanced with alky/meth than a regular map. My meth/alky map is completely different than my 93oct map. This might be the end all to flashes as well as soon as their timing control comes out, might even hamper piggyback sales as well.
Old Oct 13, 2005 | 10:36 AM
  #104
dryad001's Avatar
When you get a chance can you snap a picture of the air temp sensor? I have an extra hard pipe laying around, I can get a jump on this before i even get this.
Old Oct 13, 2005 | 10:49 AM
  #105
TurboBob's Avatar
Bob has plans to include a switch so you switch between a race/meth map and a normal map. .............
Actually that feature is already in the software,. The Aux fuel settings are engaged when the purple wire in the speed-density (6 pin) harness is energized. There is an entry in the AFR tracking page to shift the target AFR when that input is activated as well...
IAT sensor is 3/8" NPT, its a GM standard sensor.
Bob
