Help setting up UTEC
Old Feb 18, 2006 | 10:26 PM
nrcooled's Avatar
I will be getting my car back from the shop soon and I need to put a safe non-agressive base map on it for break in. I have read through the manual 3 times and I would like to know where to start.
My setup is this:
2.3l stroker
780cc injectors
GSC 272/272
255lph fuel pump
AEM Intake
MBC @ 11psi (for break-in period)
stock 16G
After break-in I will be going to TXS for a dyno tuning session but for break-in I would like to get a feel for the UTEC and setting it up.
Does anyone have a map for a similar car or is anyone local that can give me a hand setting it up? I am in Stafford, VA and I am will to drive to get help.
Any advice/help would be greatly appreciated.
Old Feb 19, 2006 | 07:08 PM
Spooldyou's Avatar
thats alotta fuel for a stock turbo.
You have a Wideband?
Old Feb 19, 2006 | 07:18 PM
Jared622's Avatar
With more displacement won't he need more fuel. I am not sure on that I am just shooting in the dark.
Old Feb 19, 2006 | 07:28 PM
Spooldyou's Avatar
^^^^^^^ Going to need to add and take away some places. esp if you wanna run it conservative.
Old Feb 20, 2006 | 03:23 AM
WarmPepsi's Avatar
utec can scale it, not an issue, wouldn't go any bigger, bit i got 750's on the stock turbo, you just set and deal with it.
Old Feb 20, 2006 | 06:51 AM
nrcooled's Avatar
I am giong to be running a WBo2 on the car plus I want to play on the safe side with the fuel. I know the idle will need some work so I will be doing my damdest to keep it drivable.
Old Feb 20, 2006 | 03:51 PM
Ultimate CC's Avatar
I guess the best place to start is load the base map from turboxs, adjust the fuel to get it on the rich side and then start doing logs, and posting them, we can try and help you build a map that will be pretty safe. I dont know anyone who would have a map for a 2.3 on stocker so I can't help you there. I have a safe 272 map that I was given and modified slightly for my own car that I could post but I am not sure how much help it will be.
Old Feb 20, 2006 | 03:56 PM
nrcooled's Avatar
Your safe 272 map would be great. At least That would give me a starting point for the cams and all I would have to do is compensate for the additional MAF frequency that I am anticipating.
Old Feb 20, 2006 | 04:06 PM
This is in part thanks to Nez136 as he originally sent me a version of this map which in turn I modded for my car. The fuel trims will be way off. Actually try the map loaded as injectors as I believe he is using 780s as well.
File Type: txt
File Type: txt
Old Feb 20, 2006 | 04:12 PM
nrcooled's Avatar
Thanks!
06 SLOW EVO
Jul 11, 2007 07:10 PM
MaxKanisha
Jul 2, 2007 08:45 AM
Stew
Jul 7, 2006 01:17 PM
ironmedic
Mar 28, 2006 07:48 PM
dangerous8
24
Sep 7, 2004 06:45 AM
