COBB EVO AccessPORT released and DYNO results
Old Oct 25, 2007 | 07:54 AM
  #121
CPA5's Avatar
Negatory on the o2 housing......depending on how things turn out after PRo-tune software is out and Stephen can do a little custom tuning maybe I'll look into that.
I'm not too sure if at this (relative mild) upgrade stage if it would be worth the expense....kind of like upgrading the intercooler....I've been told until the stock turbo is pushing 24psi or so an intercooler usually loses too much pressure drop to make sense.
Next year before summer I'm thinking on either Cosi cams or Meth.
FYI to COBB.....the other day after having Stage 2 91oct loaded as the REFLASH I decided to go into the change map section of the AP just to look at the other maps...and so after I browsed the maps I just canceled out since I wasn't actually going to load anything new....well the next day I went to start the car and it wouldn't start.......no big deal I just re-set the ECU and everything was fine.....but maybe this is something to look into...as I mentioned I never did change the REFLASHED map or anything....so I wouldn't assume that just by looking at the different maps should throw a TRIP or whatever into the system where the car wouldn't start......ANYWAYS JUST FYI ON END USER USAGE
Old Oct 26, 2007 | 12:30 AM
  #122
DeeezNuuuts83's Avatar
^ I'd also like to see a test using the economy map... if possible, maybe a dyno run (just so we know how much power you're giving up for insight on how much pulling power it'll have when passing up cars on the highway with that map loaded) but of course, more importantly a comparison of the fuel efficiency compared to before under similar conditions.
Old Oct 26, 2007 | 08:08 AM
  #123
IA Performance's Avatar
Former Vendor
I just updated our FAQs (found in 2nd post on page 1):
Q: How easy is it to install
A: super easy, see video below of actual install
DeeezNuuuuts83- The following is assuming ECONOMY on the EVO is similar to SUBARU:
The key to an Efficiency map is to generate enough HP to sustain speed on the freeway. It will have enough to pass cars, etc. COBBs Efficiency map specifically states it is not intended for spirited driving. Your boost will be defeated to wastegate spring pressure (I think ~1bar on EVO). Timing map will be lightly adjusted and AFR for closed loop may also be adjusted. Subarus see 1-4 mpg change. Each driver is different, etc.
Stephen
Old Oct 26, 2007 | 08:39 AM
  #124
CPA5's Avatar
Stephen--
Looks like that girlfriend of yours has got the skills of a film editor there
Nice vid on install.....I would of went with some MuzacK from like the Beatles...but that's just me!!
Old Oct 26, 2007 | 08:40 AM
  #125
CPA5's Avatar
HEY Deezers......don't you sleep bro?....up at 1:30 asking AP questions...now that is hard-core
Old Oct 26, 2007 | 09:39 AM
  #126
Yesterday was my birthday, so I had plenty of juice to stay awake.
Old Oct 26, 2007 | 10:46 AM
  #127
Former Vendor
her skills shine through more on this one
Stephen
Old Oct 26, 2007 | 12:53 PM
  #128
CPA5's Avatar
WOW 10 SEC. CAR USING THE AP.........EVERYONE SHOULD USE THIS TUNING METHOD!!!
JUST JOKING
Old Oct 26, 2007 | 03:24 PM
  #129
cain's Avatar
i lucked up yesterday and got the last one that IA had in stock. i will say that the install and ease of use is simple/straight forward. and yes, to those who may not believe it--there is a very noticeable difference throughout the entire powerband with the stage 2 even on this 91 octane **** out here in AZ .
a big bump to the crew over at IA great company and staff to work with
Old Oct 27, 2007 | 05:33 PM
  #130
CPA5's Avatar
Great to hear another evo in Az using the AccessPORT
Old Oct 27, 2007 | 06:08 PM
  #131
TheEvolutioner's Avatar
IA is this true?, no more in stock I remember you saying after the last one it will be on back order for a month.
When do you expect more? Ill be ready to buy next week.
Old Oct 28, 2007 | 01:51 AM
  #132
EvOcHaRgeR's Avatar
Let us know what the results are like with our **** water 91 octane
You think 91 is bad in Alaska all we have to crap 90! So I have to use this torco mix to up the octane to 93 so I always have this added cost for gas!
Old Oct 29, 2007 | 01:45 AM
  #133
EvOcHaRgeR's Avatar
Hey what is the benefit of using the AP over ecuflash? Other than being able to store and flash different maps on the fly......
Old Oct 29, 2007 | 07:48 AM
  #134
CPA5's Avatar
Someone else with more info should interject...but here are some bennies:
Read out live data...like RPM/MPH/Throttle Position/Coolant Temp/Intake Temp/KNOCK COUNT
Calculates 0-60time & Quarter Mile Time
Reflash back to stock in seconds
Security Mode/Valet Mode/Economy Maps for better MPG
Store different maps....ex: 100 oct map/meth map/etc...and upload in seconds
Soon Pro-tune/Street-tune software will be out and then you could essentially get 'customed' tuned by a tuner or yourself....which leaves nothing that ECUflash can do that AP will not
Hope this helps......
Old Oct 29, 2007 | 07:51 AM
  #135
Brian's Avatar
I would like to believe that but that's likely untrue. I wont go into it any more detail because whenever anything other than talking up/selling cobb products is done in this thread people get butthurt.
