Turbo!
Old Jul 17, 2007 | 06:09 AM
  #106
KillahB's Avatar
Originally Posted by kungfugirl
i believe they are different, if memory serves me, i had to replace a couple things while i was trouble shooting my car for what ended up being a leaky gasket
Ah ok, I see.....
I'll check it out with a higher power though and see what I can research.
Old Jul 17, 2007 | 07:38 AM
  #107
Shingen's Avatar
I emailed the original owner of the turbo... well the second owners of the kit. This is what he said. What do you guys think?
Originally Posted by gbwaacha
I had a boost controller set to about 7psi. They kit ran strong the only problem i was having was i kept blwoing gaskets so i would advise you to get the header welded to the uppipe. I also did not like the sound of the open wastegate so i had it piped into the exhaust which sounded sweet except for the fact that i kept getting that exhaust leak. The only other problem i was having was the car was idling in traffic at liek 3.5 rpm so i was liek F this and got rid of the kit. Two weeks later the car dies and i find out i had a short in the ecu from when i had the rrm piggy hooked up. So basically everything ran great except the stuff i neglected on my own end of the car. I put about 15-20k miles on it but i picked it up used on this site from pgmike. Anything else just let me know
Drew
Old Jul 17, 2007 | 07:52 AM
  #108
crypto's Avatar
Former Vendor
wow, so you are this kits 4th owner.
doesn't sound like the kit has any serious problems. I would bet his idling issue was because of the ECU
you may wanna triple check everything though, just incase
Old Jul 17, 2007 | 10:41 AM
  #109
Shingen's Avatar
Well the 3rd owner doesn't coun't because he didn't even put it on... so I'm like the third... Most likely well over 50k on this kit. That doesn't give me a warm and fuzzy.
Fox
Old Jul 17, 2007 | 10:47 AM
  #110
crypto's Avatar
Former Vendor
the RRM kits are pretty reliable though. There are guys on here with like 40K miles on them with no issues.
you should be fine. just keep up the maintainance
Old Jul 17, 2007 | 11:29 AM
  #111
Shingen's Avatar
Well according to pgmike's sell thread he only had 10k miles on the kit... so that puts it at about 30k miles at the most.
So that's not so bad.
Fox
Old Jul 18, 2007 | 05:18 PM
  #112
Shingen's Avatar
Anyone know where I can pick up a compatible widband gauge to read off of a LC-1 Innovate WO2 sensor?
I know it's cheesey, but I want to preinstall the guages before I install the turbo to save time. It's going to take me several weekends to do everything so I figure I can get all of the gauges set up in advance.
Right now I have a autometer boost, and egt guage... I'm adding the wideband, and possibly a oil pressure guage. Better safe than sorry, right?
Also anyone know where I can get looms of wire for cheap?
Fox
Old Jul 18, 2007 | 05:55 PM
  #113
kungfugirl's Avatar
my suggestion on oil pressure is prosport gauges and the sandwhich adapter they sell here.
fastwrx.com
Old Jul 20, 2007 | 06:53 AM
  #114
Shingen's Avatar
Just purchased a wideband gauge... for a gift turbo this is starting to get expensive.
Anyone know what size wastegate gaskets I need to get? Once I have them in I drop the turbo in and be boostin!
Fox
Old Jul 20, 2007 | 07:00 AM
  #115
クリス's Avatar
Fox
It should be 35-38mm. That's the wastegate size that comes with the kit :3
Old Jul 22, 2007 | 06:43 PM
  #116
Shingen's Avatar
Are the Ebay gaskets alright to buy? If not any sugestions on where to get them without costing me an arm and a leg?
Fox
Old Jul 22, 2007 | 07:37 PM
  #117
kungfugirl's Avatar
scroll down son!
http://www.roadraceengineering.com/f...andgaskets.htm
Old Jul 22, 2007 | 07:47 PM
  #118
kungfugirl's Avatar
ah pgmikes old kit. get the best wastegate gasket possible i think he had issues with his wg gastket always messing up.
Old Jul 22, 2007 | 07:56 PM
  #119
Shingen's Avatar
Which leads me to this question, which one is the best?
Fox
Old Jul 22, 2007 | 07:59 PM
  #120
kungfugirl's Avatar
Cool
Fox
Well i think the composite one is supposed to be best especially with an uneven flange surface, i am picking one up this weak. I think with the fact that he had issue with his WG gasket u should pick up the more expensive one, and maybe two just to have em because you dont want exhuast leak when your boosted, you'll feel slower than NA.
On that thought i sugest you have your flange surfaces resurfaced. u scan do it with a hand sander and some paper from home depot. that way they are smooth and even.
