Yet another thread about Turboing a 03 lancer.
Old Jun 4, 2012 | 08:17 PM
  #1546
03lances's Avatar
I am noticing it right off the gauge not the logging.
Old Jun 4, 2012 | 08:23 PM
  #1547
RoadSpike's Avatar
Maybe you can confirm its off with the front o2 sensor. The sensor should be switching back and forth at 14.7 afr.
Old Jun 4, 2012 | 08:32 PM
  #1548
03lances's Avatar
This was what I was thinking just wasnt sure if it would work logging both of these and comparing voltage of front 02 with afr reading of wb. when cruising it like to fluctuate between 15.2 14.7. Shouldnt the median afr be more closer to 14.7 and not 15.0?
Old Jun 5, 2012 | 09:09 AM
  #1549
RoadSpike's Avatar
honestly that sounds pretty normal to me. I think the o2 sensors just aren't fast enough to make it a steady 14.7. The mitsubishi doesn't use a voltage to afr calculation to make the fuel trim more robust it just has a switching voltage which is sorta lame :P
Old Jun 5, 2012 | 08:11 PM
  #1550
03lances's Avatar
K I wasnt sure on that
Old Jun 6, 2012 | 08:50 PM
  #1551
Grind3r's Avatar
03lances ..... Been reading through most your thread from the beginning. Gotta say, Nice Build.
I'm just in the beginning stages of mine. Man is it addicting.
Old Jun 6, 2012 | 09:14 PM
  #1552
03lances's Avatar
Thanks Grind3r, its a long read but well worth it there is a TON of info all through this thread I tried to post stuff about anything and everything I was doing or having issues with my car. Looking forward to seeing some more numbers from your car.
Old Jun 6, 2012 | 09:27 PM
  #1553
Grind3r's Avatar
I'm looking forward to better numbers for sure. Unfortunately my stock MAF is chocking out between 1500 and 2000 rpm on launch. Aaron was able to only do so much. But with the rest of upgrades in the coming weeks and adding the 4bar MAP and deleting and removing the MAF altogether, Things should be looking much better. I will definitely give updates afterwords.
By the way, your thread did help me a lot when I began this new obsession a few months ago.
Old Jun 18, 2012 | 07:35 PM
  #1554
03lances's Avatar
Anyone know how to test a manual boost controller to see if its bad? I pulled off my manifold/turbo assembly on friday determined to figure out what my rattle was during deceleration and rpm drops in general. Found my turbo was not quite clocked right causing the forge adjustable wastegate to give the internal flapper slight play. After I got it back together I went for a drive and was overboosting to 18 psi for a couple pulls then it dropped to 13, after I was satisfied it wasnt going back up I turned up the mbc only to find it wouldnt raise. Pulled mbc off cleaned it and then it went down to 11 lol. Took it off again and looked over it and cleaned it again meticulously and put it back on and dropped to 9 wtf??? now I am stuck at 9 psi with a tune meant for 15
Old Jun 18, 2012 | 07:37 PM
  #1555
03lances's Avatar
By the way my spool is much more responsive now after this so the internal door was definately open slightly during spool up.
Old Jun 19, 2012 | 08:50 AM
  #1556
Grind3r's Avatar
Sorry too hear about your newest problem. I actually was thinking about adding a MBC to my setup, but have read up on them over the last few weeks and have found quite a few complaining about them going bad or just getting a bad one right from the start. Mostly Ebay ones. Bad Springs, Ball sticking and such.
I am actually curious if your Turbo clocking and loose Wastegate flap may have been showing you a false reading before you fixed that issue and was making it seem the MBC was working properly before.
I'm sure others will chime in and maybe will have a more solid answer to whether the MBS is bad or how to test it though.
Hope your able to get it sorted though.
Old Jun 19, 2012 | 09:52 AM
  #1557
ryancb's Avatar
whats up with WA having the most turbo'd lancers haha? I know of 4 for sure with you. I think we need to have our own meet
Old Jun 19, 2012 | 10:14 AM
  #1558
Grind3r's Avatar
lol....I just jumped on the turbo'd bandwagon a couple months ago. lov'n every minute of it too. A meet would be cool. Could always crash a honda meet
Old Jun 19, 2012 | 02:52 PM
  #1559
03lances's Avatar
So I pulled my wastegate back off and pulled the yellow spring out and put in the blue spring its supposed to be 14-20# spring and bypassed the mbc all together. Hitting 10psi maybe 11 barely sometimes but not 14 where it should be at least. Going to do another boost leak test but anybody have any other ideas? Turbo looked fine when I pulled it off friday still no shaft play and free spinning.
Old Jun 19, 2012 | 05:45 PM
  #1560
03lances's Avatar
Well no boost leaks, however one quesion, how do you get all the intake valves closed to do a proper test? I can always hear slight hissing and find it to be inside the intake passing through those intake valves.
