Yet another thread about Turboing a 03 lancer.
Old Aug 17, 2009 | 09:19 AM
  #226
03lances's Avatar
Ah gotcha I was a little confused I seen what looked like a sending unit already installed on the side of my motor... Ok so would a tein fron performance strut bar for the evo 9 fit on my 03 es?
Old Aug 19, 2009 | 03:45 PM
  #227
03lances's Avatar
Alright guys so just bought a new AEM Uego and need to know what the cable is I need to log with it? Is it a specific cable or just like a standard usb cable? Tried finding one online but dont know the official name so I am coming up empty.
Old Aug 19, 2009 | 04:16 PM
  #228
senate6268's Avatar
You need to make one with an RS-232 connector from Radio Shack to connect to the blue serial output wire on your AEM UEGO. Instructions can be found here:
https://www.evolutionm.net/forums/ec...tructions.html
Old Aug 19, 2009 | 04:30 PM
  #229
03lances's Avatar
Thank you !!!!!!!!!!!!!
Old Aug 28, 2009 | 06:57 PM
  #230
03lances's Avatar
Alright down to needing oil lines, DP and exhaust, and MBC then BOOOOOOOOOOST!!!!
So I am thinking I am going to start by scaling my injectors to 412 b4 the initial startup then go from there does this sound like a smart idea?
Old Aug 28, 2009 | 07:08 PM
  #231
senate6268's Avatar
You can scale your injectors now and get your latency values straightened out for idle and cruise so that all you have to tune for it WOT and cruising in boost. It's a very good idea.
Old Aug 28, 2009 | 08:54 PM
  #232
03lances's Avatar
Alright thanks senate, since I have prolly done 100+hrs of research on the building of the turbo kit I figured I better start my research on the tuning of the turbo kit as I am pretty sure I have my info for the install now Very confusing to say the least but it doesnt discourage me a bit I love a challenge
Old Aug 30, 2009 | 01:06 PM
  #233
03lances's Avatar
Ok guys so since I am getting very close to slapping this thing on I wanna be comfortable with the tuning aspect, I want you experienced people to give me an opinion on if this is a good base to start with. So the top High and Low are the stock maps for comparison and the bottom 2 are my adjusted maps. I rescaled my injectors to 412, rescaled my load values to 120 by taking loads 10 20 30 and combining them in one column as they are pretty much identical in the stock rom. Then in the 120 load column I dropped the afrs .5 in relation to the 100 column and used the interpolate 2d to give it a smooth progression. Lemme know how it looks and also I found this page for the stock 440 latencies however I only see 5 values and ecuflash gives us 7 values to define so not sure what I should do there. Also should I adjust my timing or wait till I do some datalogging? Thanks
EDIT:
Ok also anyone out there logging there stock maps? I have been logging mine and When I do some 3rd gear WOT pulls I get lots of 1 and 2 knock counts and even had a 4 in there with some 3's anyone else having this in there logs, another log shows 14 count???!!!!!!! I think my knock might be higher due to my cheep fuel taste lol regular (will be changing to premium soon b4 and after the turbo goes in.
Old Aug 30, 2009 | 06:19 PM
  #234
senate6268's Avatar
You might want to richen up a bit above 90 load from 4500-redline to get your AFRs around 11.5 or so. I would also have the lowest load value be 10 so that you won't have idle issues.
Old Aug 31, 2009 | 01:53 AM
  #235
03lances's Avatar
OK thanks man I will do that, change the first load value then from 100 on I will drop the afrs a little to richen it up and go from there thank you so much
Old Aug 31, 2009 | 12:09 PM
  #236
Green_Bandit's Avatar
Nice! Keep going man! I've been waiting for you to put this thing on for a while now...
Old Aug 31, 2009 | 12:19 PM
  #237
03lances's Avatar
Thanks Green Bandit!!!!!! I wanna make sure I have everything I need before turning a single wrench. Including not just parts but the knowledge too
Old Aug 31, 2009 | 01:23 PM
  #238
imalancerman's Avatar
03, you better be available when i do my turbo build. Imma have some questions. And prob need a helping hand lol.
Old Aug 31, 2009 | 02:02 PM
  #239
03lances's Avatar
You got it Lancerman us west coast guys gotta stick together lol
Old Aug 31, 2009 | 02:09 PM
  #240
Lemme know when you start yours and im more than happy to make the trip up to help ya out.
