Yet another thread about Turboing a 03 lancer.
Alright so the head is off I am getting ready to clean up all the surfaces and install the studs, I figure I will install my 440s while the head is off to since I pulled it with the intake mani attached. I also installed my T fittings for my coolant lines, I have been taking pictures through various stages of disassembly I will post when I get time.
Hmmm no one has posted... either my thread is dead or everyone is waiting patiently. Anyways so the head is on with the new gasket and the arp head studs yay
and of course took plenty of pics will probably post them after I get the engine together with the new clutch too realized today my brother in law still has my engine hoist so gotta go over there early tomorrow and grab it.
Going in this weekend so this week I HAVE to get the clutch and studs etc. in. BTW any of you manual lancers pull your engine without the trans? not sure if there will be enough clearance but it will save me about 6 hours or more of labor if I can pull the engine to get to the clutch since all I have to do is unbolt the ac pump and bell housing bolts.
trans will come out np. i think it took my friend and i 3 hrs tops for out/install/and back in.
id say pull the trans and then the engine for more room. less hassle imo, if yur already in there and pulling everything.
josh
josh
I realllllllllly did not want to do that but I will reinstall them as one unit to make things go in smoother. Now I can pull the pan without issue which makes up for it a little. So tomorrow my flywheel comes off and gonna shave it down a little and resurface it then install my stage 2 clutch
Alright so an early turn in tonight I pulled the fuel rail and went to install my 440s and ripped a damn o ring lol so gotta wait until tomorrow to get another one. I started the intake manifold port match mod I found on this site and is working good so far but damn is it loud so dont feel like pissing off the neighbors lol. I am gonna post some pics of my progress tonight here in a few
alternator pulled
tees for the turbo coolant lines
under the valve cover looks pretty clean to me
right after I pulled the head, pistons look good just normal carbon buildup
After a couple hours of cleaning looks pretty good although I should have pulled
up the other 2 pistons and cleaned them too, all the dark splatters around the engine bay are from me blowing out the oil in the stud holes
studs are in woohoo
little dirty under here but it will clean up nice
old head bolts
getting ready to clean the head surface
much better now
head reinstalled with the studs, notice anything missing that was there before?
yup the damn intake manifold was in the way when I went to install the head with the studs so I had to pull it so I figured it would be a good time to install the 440s and port match
out with the old, in with the new
as far as I got with the port match before deciding I didnt want the cops here because of the noise lol
stock flywheel
after getting it back from resurfacing it, much better now
alternator pulled
studs are in woohoo
old head bolts
much better now
stock flywheel
It looks really good comgrats man, for your 440cc injectors did you you have to purchase a new manifold to fit those, or will the stock fuel rail work with 440cc injectors? and do I need to do any modifications to the fuel rail in order to make the fuel flow properly through the injectors, like making the holes on the end bigger?
How much longer?
