Yet another thread about Turboing a 03 lancer.
Old Jan 28, 2010 | 08:14 PM
  #661
link62's Avatar
ouch yea that doesnt look to good idk if you can straighten them out
Old Jan 28, 2010 | 08:28 PM
  #662
03lances's Avatar
Ok so been working on it a little you guys think it will be useable?
Old Jan 28, 2010 | 09:22 PM
  #663
03lances's Avatar
Dont think I can get it much better than this without making it worse lol
Old Jan 28, 2010 | 09:38 PM
  #664
JRR's Avatar
JRR
ooooofff dang thats not the prettiest maf ive ever seen!
josh
Old Jan 28, 2010 | 09:47 PM
  #665
03lances's Avatar
josh
I know right so much for my "mint" maf I was getting. I messaged the dude lets see what he says...
Old Jan 29, 2010 | 01:01 AM
  #666
03lances's Avatar
Ok guys so I am having the same issue as JRR with not being able to pull my rom off my evo 8 ecu. I have ecuflash 1.29.906, which was the original version I used to pull my stock rom off my stock ecu so long ago, but now I cant pull my rom off either?? it recognizes my cable as the Mitsubishi 1.3 with the serial number so no problem there, although here is the starting log when I first open ecuflash
[01:33:51.312] Version 1.29.906
[01:33:51.375] 8 memory models read.
[01:33:51.437] Unable to find parent metadata evo7base
[01:33:51.437] ROM metadata models 91890014.xml is invalid.
[01:33:51.453] Unable to find parent metadata evo7base
[01:33:51.453] ROM metadata models 92290022.xml is invalid.
[01:33:51.453] ROM metadata models 93270017.xml is invalid.
[01:33:51.453] Unable to find parent metadata 98720010
[01:33:51.453] ROM metadata models 97250005.xml is invalid.
[01:33:51.453] ROM metadata models 98720010.xml is invalid.
[01:33:51.468] Unable to find parent metadata evo7base
[01:33:51.468] ROM metadata models 98720012.xml is invalid.
[01:33:51.468] ROM metadata models EM9872.xml is invalid.
[01:33:51.468] ROM metadata models JM9229.xml is invalid.
[01:33:51.468] 18 ROM metadata models read.
[01:33:51.468] checksum module "subarudbw" loaded.
[01:33:51.468] flashing tool "wrx02" loaded.
[01:33:51.468] flashing tool "wrx04" loaded.
[01:33:51.468] flashing tool "sti04" loaded.
[01:33:51.468] flashing tool "sti05" loaded.
[01:33:51.468] flashing tool "mitsukernel" loaded.
[01:33:51.468] flashing tool "mitsukernelocp" loaded.
[01:33:51.468] flashing tool "mitsubootloader" loaded.
could not finding the metadata tables have something to do with it?
Old Jan 29, 2010 | 11:34 AM
  #667
03lances's Avatar
Hee is what I get when I try to read my rom
Nothing, the read from ecu is highlighted above like I can, but the window that comes up has the read button faded? you can see my cable is shown in the bottom right.
Old Jan 29, 2010 | 04:55 PM
  #668
senate6268's Avatar
You're missing all the files in:
C:\Program Files\OpenECU\EcuFlash\rommetadata\read templates
Old Jan 29, 2010 | 07:48 PM
  #669
03lances's Avatar
Ok so I do have some files in that folder but dont know where to get the others. Did alot of searching in the ecuflash forums with no luck , Anyone know where to get these? Also I cant imagine this would stop me from being able to read my rom any ideas there?
Old Jan 29, 2010 | 07:56 PM
  #670
senate6268's Avatar
The read templates should've been installed with EcuFlash. I might suggest re-installing.
Old Jan 30, 2010 | 01:48 AM
  #671
03lances's Avatar
SUCCESS!!!!!! ITS FIXED!!!!!!!!! I successfully pulled my rom, tomorrow I pull my evo rom yay!!!!!! The issue was exactly what senate said although didnt realize what he meant at the time, in the ecuflash options I noticed the metadata file was only accessing the lancer file for everything, I changed it to access the whole mitsubishi folder (since I have no scoobies) and moved the read templates folder into the mitsubishi folder and VIOLA!!!!
Senate rocks once again
Old Jan 30, 2010 | 03:21 PM
  #672
japordie's Avatar
nice keep it going
Old Jan 30, 2010 | 07:52 PM
  #673
03lances's Avatar
Ok guys so I am ready to flash my evo ecu and start it up but HOW DO YOU SWITCH THE WIRES!!!!!! I have tried a few things and I am afraid of messing them up I am trying to find some kind of release that will allow them to slip out of the plug so I can swap them, anyone please I am stuck now
Old Jan 30, 2010 | 08:11 PM
  #674
03lances's Avatar
UPDATE:
So I figured it out got em switched and she FIRED RIGHT UP WOOHOO, idling like a dream right now just swapped over my injector settings and left the maf as is and sounds awesome!!!!!
Old Jan 31, 2010 | 02:34 AM
  #675
vityenyka05's Avatar
Talking :)
thats crazy man, great job.. man, i'm gonna need major help from you when i get my little t25 into mines.. i'm looking around for a evo 8 ecu.. fr now my trany is all apart, i had to replace a few bearings, and hopefully soon i'll get it all together, just crazy busy with work.. winter time sucks if ur a painter at a professional body collision shop. i've got my manifold and the tubo, plus catless down pipe, full greddy catback exoust. and my t25 turbo, that i'm rebuilding, since its got a little shaft play..i know how to install everything, but i suck at tunning, i'm asking for some help.. let me know whats better to do.. i've got injectors.. it would probably be so much easier to use someones tune, and try to go from there, and mess with it a little, than tuning from stock huh?
