Yet another thread about Turboing a 03 lancer.
josh
Well I have a feeling part of my lean issue is just due to my lack of knowledge in the whole tuning thing. As you can see though I managed to dramatically bring them down in my main area of concern (3500-4500), the first set with the 13 in there my fuel map was literally bottomed out at 7.4 and my maf scale maxed. Now with 11.8 in that same rpm range with little changes to different tables
josh
Yo guys anyone out there know if a bored fuel rail would supply my injectors with more fuel? To be more specific I think my 440cc injectors are not getting the fuel supply due to my stock fuel rail not able to handle the flow of the walbro and 440cc.
is this a problem im going to run in once I turbo my car? I thought the 440cc were a direct fit and if that was the case they should work just fine?
Yes the 440s are a direct fit and I have since this post discussed with senate and determined the fuel rail probably is not the cause, it could be my stock fpr, I am looking right now to either get an evo fpr and mod my fuel rail to fit or get another aftermarket rising rate fpr.
If you dont mind JRR can you post some of your afrs with a wot 3rd gear run? I cant for the life of me get mine below the 12.0 mark around 4-4.5k rpms. I had it once but for all I know it could have been the weather that day giving me the better afr readings
im running a bored fuel rail with 440s and an aftermarket fpr, i think im getting enough fuel lol, also is the 399 maf the evo one, if so im gonna get it if it makes a difference although i thought the evo and lancer maf were the same.....
josh
